[SOLVED] “No signal” on my tv. Qled light VGA and Boot remain on.
Apr 2, 2021
Ryzen 9 5900x
Asus Prime X570-pro
MSI Radeon RX 5500XT
Corsair Vengeance Pro (2x8gb)
Seagate Barracuda 2TB hdd
Seagate firecuda 500gb sshd
Corsair CX750F rgb
First time building a pc.
Qled lights light up during POST, VGA and Boot remain on. I’ve reseated the GPU, Ram. Removed one of the Ram. Cleared the CMOS. Checked all cables. The Boot Qled was the only light on until I cleared the CMOS. Now both are on.
I’m connecting it to a tv via HDMI. Tv says “no signal.” Also not sure if it requires a bios update. If so is the only fix to get a loan boot kit from AMD?
Thanks in advance.
The Asus Prime X570-Pro needs a BIOS update to support Ryzen 5000. All the motherboards X570, B550 and B450 needs a BIOS update to support Ryzen 5000.
Unfortunately for you the board you have does not have a Flashback function so you cannot update the BIOS without a CPU installed.
You need a CPU already supported on that board to flash the board for the Ryzen 5000 CPU. You can lend a CPU from AMD or you can go to a local shop so they can flash your BIOS or you buy a Ryzen 3000 and you refund it after the BIOS flash.
https://www.amd.com/en/support/kb/faq/pa-100#faq-Short-Term-Processor-Loan-Boot-Kit
The version needed minimum for that CPU to work on that board is
Version 2606
2020/08/17
The latest BIOS update (Non Beta) is...
Version 2606
2020/08/17
Version 3602
2021/03/12
Version 2606
2020/08/17
Version 3602
2021/03/12
Thanks for info! I really appreciate it!
