Hi everyone,
I recently put together a water cooled PC with 2xRadeon 6990 and an Intel i7 2600k. The cooling itself is really quiet as I am using low RPM fans, but the PSU fan is totally ruining my plan for a silent system. It's by far the loudest component in the build. Originally I had a Corsair AX1200, which I replaced with a new unit because of noise problems. The new unit was a bit better, but still not quiet enough. Then I switched to a Nexus RX 1.1k. This one is a bit quieter still, but again far from what I hoped.
So I was wondering if anyone has suggestions for a really silent 1.2+kW PSU. I realize that standard PSUs with such output are bound to be noisy. But what about some custom design, it could even be an external unit? Price is not an issue. I live in Switzerland so it would be better if I can buy something from Europe, but shipping from the US is also an option.
I could not find a suitable off-the-shelf PSU and was thinking of using 3 fanless PSUs (1 for each graphics card and 1 for the rest of the system) ? Do you think that's a good idea? Which brand is most reliable? Do these PSUs need some minimum amount of air flow to be cooled properly or would it be sufficient to just leave them in the open? I don't want to add more fans to the system and ideally I could just place the PSUs outside as they won't fit in the case.
Of course any other suggestions are welcome. I would prefer a single unit of some sort but did not find anything suitable.
Cheers,
Mitko
Cheers,
Mitko
