Hello all. This will be my first build, and it has been a steep learning curve getting to the point where I felt like this was even feasible. I have been putting together a list of parts for this prospective first build, based in large part on what I have read on this forum. Despite most of the advice on this site being geared towards gamers, my build is intended primarily for research- handling large data sets, and number crunching with maximum ease. That said, this will also be a home computer, so fluid multi-tasking and smooth overall performance are a priority as well. Thanks to everybody who puts the energy into helping the supper-green like me. The advice on this sight has been a huge help. I think I would have given up long ago and opted for an overpriced Dell workstation if it had not been for the hugely helpful stickies and many relevant posts on this sight. Forgive the length of this post, I was biased toward being thorough over concise.
APPROXIMATE PURCHASE DATE: As soon as possible. But can be patient if it’s worth it
BUDGET RANGE: $1,500- or as close as possible After Rebates
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Processing large datasets using MATLAB and Stats packages (SPSS and/or SAS and/or R); MS Office, multi-tasking (web-browsing), multimedia (movies/music), no games for me.
PARTS NOT REQUIRED:
-Video Card, GeForce 9800 GTX+
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130339&nm_mc=EMC-IGNEFL070610&cm_mmc=EMC-IGNEFL070610-_-EMC-070610-Index-_-DesktopGraphicsVideoCards-_-14130339-L0E
Wanting an NVIDIA card to for potential future experimenting with CUDA based programming in MATLAB, I recently bought this at a very reasonable price from Newegg.
-Sound card, speakers.
PREFERRED WEBSITE(S) FOR PARTS: Have been looking mostly on Newegg but am open to suggestions.
COUNTRY OF ORIGIN: USA.
PARTS PREFERENCES: Prefer to build this system around Intel I7 quad core.
OVERCLOCKING: Maybe, slight.
SLI OR CROSSFIRE: No.
MONITOR RESOLUTION: 1920x1080 - 1920x1200.
ADDITIONAL COMMENTS: I will not be doing any gaming on this computer and am primarily interested in something stable, solid, and upgradeable. Something that will perform well with lots of applications running, including, at times, MATLAB running batch processing scripts. My primary concern is overall performance at a reasonable price, not leading edge, but not far behind. The following build is based in part on combo deals currently available through Newegg. It is also (mostly) based on parts that where repeatedly vetted and recommended by folks who contribute to this sight
CPU & MOBO (Combo) - $494
i7-930
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115225
I am wondering if the increased bandwidth provided by triple channel setup will help when performing operations with larger datasets? From what I have read the performance boost is negligible for many operations. Also, I assume the 1366 will be around for a while longer than many other cheaper setups? I may experiment with overclocking to 3.6 Ghz. I will not be taking advantage of SATA 6gb/s or USB 3.0 for now but assume I likely will in the future.
ASUS P6X58D-E LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131641
I could not decide between this and the GIGABYTE GA-X58A-UD3R. Either would likely more than meet my needs, but with the combo the prices are matched. I am wondering about the real world advantage of 16 vs 8 phases for the P6X58D-E? Any opinions on which board will provided greatest stability and reliability over time (I am sure there is
CASE & PSU (Combo) - $179
-SeaSonic X650 Gold 650W ATX12V V2.3/EPS 12V V2.91 SLI Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151088
A little more power then I need and excellent efficiency. Also, I think the modular design might make the first build a little easier.
-LIAN LI Lancool PC-K58W Black 0.8 mm SECC, Plastic + Mesh ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112238
Anyone familiar with this case who could provide suggestions for additional fans for this case, and priority placement for additional fans? I live in Tucson, and will have this machine running during the day in up to 82 degree room. Scary 😱 ?
OR
-COOLER MASTER HAF 932 RC-932-KKN1-GP Black Steel ATX Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
For a little more and a loss on the Combo savings above, I was considering this case as will. Mostly interested in functionality- Would this case or another provide superior ventilation/cooling, and/or significantly greater ease for first time build.
CPU COOLING - $50
-COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-G1
http://www.newegg.com/Product/Prod [...] 6835103065
I know this one has become pretty popular, with an increased price gouge. Is this still the best buy in this range? Sufficient for a 3.6 Ghz overclock?
RAM - $170
-G.SKILL PI Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7T-6GBPI
http://www.newegg.com/Product/Prod [...] 6820231335
OR
-Mushkin Enhanced Blackline 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model 998832
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226130&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3899435&SID=skim1402X558040
From what I understand lower latency is the priority for the LGA 1366 systems. Both seem like a good deal for CAS 7 but I am open to suggestions. Any benefit in the 1333 (Mushkin Enhanced Blackline) over 1600 (G.SKILL PI Series) given I will never take advantage of the 1600 speed? Any possible incompatibility issues with either of these kits and the P6X58D-E?
HD (Here is where I am most stuck).
I was interested in the suggestion made by many on these boards to add a smaller boot drive consisting either of SSD, High RPM HDD, for OS and high use applications; or the option of several smaller drives in RAID-0 with no separate boot drive. I really do want a setup that will require minimal tweaking and trouble-shooting once everything is dialed. These are my thoughts for potential setups for each option.
HD Setup-1
-2x SAMSUNG Spinpoint F3 HD103SJ 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive- $110
http://www.newegg.com/Product/Prod [...] 20f3%201tb
500GB will likely more than suffice for all my needs. I would run these drives in RAID-0 and keep a regularly updated system image (using Win7 or Acronis) on an external drive. My concern is the increase likelihood of failure (particularly as my OS would be on this configuration). I have looked into imaging options, but restoring RAID-0 sounds tricky and inconsistent. I do not want to risk data loss for a performance boost, but would be comfortable with the risk if I could ensure that recovery was guaranteed. Any experience? Any issues with backup and recovery, and/or overall reliability , using ICH10R “Fake RAID” over true hardware RAID?
HD Setup-2
-OCZ Agility Series OCZSSD2-1AGT60G 2.5" 60GB SATA II MLC Internal Solid State Drive (SSD) -$120
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227461
-ICY DOCK MB882SP-1S-1B 2.5" to 3.5" SSD & SATA Hard Drive Converter – Black -$15
http://www.newegg.com/Product/Product.aspx?Item=N82E16817994064&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3899435&SID=skim1402X558040
-SAMSUNG Spinpoint F3 HD103SJ 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive- $55
A great deal right now for the SSD, and hopefully based on what I have read, 60 GB would be just large enough for my OS and a few programs (MS Office, MATLAB). The SAMSUNG drive would take care of bulk storage. Still I am thinking that it may be worth holding off on the SSD for the time being, and sticking with the RAID-0 setup assuming I can insure a safe backup.
HD Setup-3
-Western Digital VelociRaptor WD1500HLFS 150GB 10000 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive -$140
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136296
In this case I would use the VelociRaptor HDD for bootup. Seems like a safe setup, but likely minimal performance gain and the priciest option.
Optical - $24
-LITE-ON Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 24X DVD Writer LightScribe Support
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106335
Its what was referenced most on these boards.
Monitor - $220
-ASUS VW246H Glossy Black 24" 2ms(GTG) HDMI Widescreen LCD Monitor 300 cd/m2 ASCR 20000:1 (1000:1) Built-in Speakers
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236049&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=
OR
-ASUS VE246H Black 24" 2ms(GTG) HDMI Widescreen LCD Monitor 250 cd/m2 50000 :1 (ASCR) Built-in Speakers
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236082&nm_mc=EMC-IGNEFL052710&cm_mmc=EMC-IGNEFL052710-_-EMC-052710-Index-_-MonitorsLCDFlatPanel-_-24236082-L0B
Trying to decide between these two monitors. The first has better specs except for cd/m2. The second has all the customer choice awards from Newegg, and is referenced here a lot. Any significant reason for choosing one over the other?
Keyboard - $15
-Logitech K300 Black 101 Normal Keys USB Wired Compact Keyboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16823126077
I am used to laptop style keyboard layout and shallow key travel.
Mouse - $24
-Logitech LX3 Gray/Black 3 Buttons Tilt Wheel USB or PS/2 Wired Optical 1000 dpi Mouse
http://www.newegg.com/Product/Product.aspx?Item=N82E16826104019
Standard wired USB mouse. Looks nice.
Windows 7 - $100
-Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
http://www.newegg.com/Product/Prod [...] -_-Product
I may opt for Pro if I decide to use the system imaging feature, but from what I have read there is free-ware that is equal or better in terms of flexibility, and likely money would be better spent on an Acronis license.
Total price before shipping, mail-in rebates, taxes, etc: $1,454.04 - $1,505.88 (depending on HD setup)
I know I included lots of questions. I don’t expect they will all be answered, but advice and experience on any of this is greatly appreciated. Specifically, I would most appreciate feedback on my HD setup options. More generally, I am most concerned about making sure there is no obvious or well known incompatibility with any of the components I have listed. Once again, reliability is the priority. Also, leads on any good deals for similar components are greatly appreciated.
PARTS NOT REQUIRED:
i7-930
OR
CPU COOLING - $50
RAM - $170
OR
HD Setup-1
HD Setup-2
HD Setup-3
Optical - $24
Monitor - $220
OR
Keyboard - $15
Mouse - $24
Windows 7 - $100
