[SOLVED] 1 partition split in 2 how to fix ?
MrGreener
Commendable
Apr 20, 2020
12
I have these 2 yellow partitions that are the same drive, how do i make them into a single blue one ??
They are both the same drive and appear as one in my computer with its full capacity. i have data on it that i wanna keep, can i do it while keeping it ?
Please show us a screencap of your Disk Management window.
" i have data on it that i wanna keep"
This indicates you should have a second copy of this data on some other storage device.
Any messing with partitions is potentially destructive.
(and you should have that backup anyways)
Reactions: Inthrutheoutdoor
it should of been 1 single part, even tho in my computer it shows up as a single partition with its full capacity, IDK why its split in 2 here
