Question 1 stick 1.2v 1 stick 1.35
First of all mixing memory is always a mixed bag of results. They may not work together at all, or they may work together but default to the slowest speed of the slowest memory stick. They may work for a while but cause bsod along the way. You can try them it wont hurt the pc per se, but results are always different. It is always best to buy a matched set and use them together.
Reactions: DMAN999
Oh oke Yeah I am planning to buy the same one but not now. But it wont hurt if I try to use them both?
Play around with them first at default settings hoping the motherboard auto adjusts. If you're able to boot with the two sticks then test them with memtest making sure there'll be no errors. Boot memtest from a usb stick and do atleast 5 passes. Youtube has tutorial vids if you want to check it out.
If auto settings fail then yeah, will have to manually input settings. Starting with dram voltage then possibly needing to muck around with ram speed and timings.
oke tnx I will try and I will comeback with the results
Reactions: boju
