P Phosphate Distinguished Jun 27, 2006 6 0 18,510 Jun 30, 2006 #1 Will this type of LAN slow down my cable modem internet connection compared to Gigabyte LAN?
The_Prophecy Splendid Moderator May 16, 2006 6,672 24 27,315 Jun 30, 2006 #2 Unless you have a connection over 100 Megabits/sec, no, it will not slow it down.
P Phosphate Distinguished Jun 27, 2006 6 0 18,510 Jun 30, 2006 #3 Thanks for the info. 2370 kilobits per second That was what I got on my current computer when I went to PC pitstop....Now let me look up the conversion. So according to this --> http://en.wikipedia.org/wiki/Megabit 2370 kilobits is only 2.3 Megabits? Something tells me that is not right?
BUFF Distinguished Dec 17, 2003 1,050 0 19,280 Jun 30, 2006 #4 That's quite possible depending where you are e.g. I'm on 4Mb cable but even then you also lose a bit due to overheads.
P Phosphate Distinguished Jun 27, 2006 6 0 18,510 Jun 30, 2006 #5 I have 3000 kilobit cable "officially" but yes it appears there are some losses. So am I right in assuming 10/100 LAN can handle cable modem at full speed? (I don't know what LAN the current computer I tested) Because if I needed Gigabyte LAN I would definitely get it.
Pain Distinguished Jun 18, 2004 1,126 0 19,280 Jun 30, 2006 #6 100base nic will handle a T3 connection, so yeah, it will be fine for cable. All consumer grade internet connections currently available wouldn't even saturate a 10base card.
