Hi there! This is my first time on this forum, but it seems to be a great resource! I'm interested in building a new desktop PC (my first one) that will work well with 3D graphics (such as modeling and rendering) as well as gaming. I also just want it to be a good general-purpose PC. I already have the 24" monitor and mouse/keyboard, so that doesn't need to be factored in. It would be great to get some advice on which version of windows I should buy, whether the parts are compatible, and if my parts can be replaced by better (or cheaper if possible!) parts. I am a college student, so I am trying to keep the price down if possible.
Approximate Purchase Date: This week
Budget Range: $1000, not including OS cost
System Usage: 3D graphics, gaming, general purpose
Are you buying a monitor: No
Do you need to buy OS: Yes - I would like advice on this. Is the $200 price for windows 7 home edition the best I can get? It's just a big addition to the overall price of the build...
Preferred Website(s) for Parts: newegg.com, but elsewhere if cheaper
Parts Preferences: Intel processor
Overclocking: Maybe later (not for now)
SLI or Crossfire: No
Your Monitor Resolution: 1920x1200
Additional Comments: I want 3ds Max to work well on this build, and the parts to be compatible with each other
Here is the build I put together today:
Motherboard: BIOSTAR TZ77B LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138352 $100
//CPU and GPU came together in a package with $20 discount + coupon for free borderlands 2 ///
$520 for combination CPU and GPU
CPU: Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
GPU: EVGA SuperClocked 02G-P4-3662-KR GeForce GTX 660 Ti 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130810
Power Supply: COOLER MASTER eXtreme Power Plus RS700-PCAAE3-US 700W ATX 12V v2.3 Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171054 $80
Memory: G.SKILL Ares Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9D-8GAB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231546 $42
SSD: OCZ Vertex 4 VTX4-25SAT3-128G 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227791 $100
Hard Drive: SAMSUNG Spinpoint F4 HD322GJ/U 320GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152244 $60
Case: COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233 $60
Let me know what you think, thanks!
