$1000 Gaming Build Help
unRaveled
118
Hey guys. This is going to be my first gaming computer build and I don't want it to be so expensive at first. So please help me decide on cheap and efficient parts. Please I don't want the parts to have cheap quality and that it would break in less than a year. I would appreciate it if the parts would be long lasting and efficient with a reasonable price. Hope I'm not asking too much. I also made a build myself. You guys can feel free to add in suggestions.
Approximate Purchase Date: This week or next.
Budget Range: $1000 after rebate.
System Usage from Most to Least Important: Gaming, surfing the internet, rendering videos and uploading, doing homework
Are you buying a monitor: Yes
Do you need to buy OS: Yes
Preferred Website(s) for Parts: Newegg, NCIX, Amazon
Parts Preferences: Doesn't matter as long as the parts are not from a cheap and crappy quality company. I would prefer parts that are reliable and efficient.
Overclocking: Maybe
SLI or Crossfire: No
Your Monitor Resolution: 1920x1080
Please take in consideration of the parts quality and guys can you check if my parts that I picked are compatible with each other? Also can a HDTV be used as a monitor? If yes than what is the difference would happen if I used a HDTV instead of a regular computer monitor. Sorry for the questions and needs. This is my first computer build and I would like to learn as much as possible and so next time I can pick myself and be less of a bother.
Here are the parts that I picked:
http://pcpartpicker.com/p/bPtE
Also is the Sapphire Radeon HD 7850 better than the MSI Radeon 7850?
Thanks -unRaveled
Hey Troll I've heard that the ASRock Z77 motherboard has bios problem. Some GPUs won't boot up with the motherboard. I'm afraid that this problem might happen with my GPU as to this board has GPU problems. Can you reccommend another motherboard that is compatible with my components that isn't too faulty and has problems?
