Hey guys, I have a problem with my CPU i7-4790k, motherboard z97x-UD5H
In idle or using chrome i get around 60-65 ºC but when going PUBG or other game it goes 88 ºC++++ eventually getting to 100 ºC. I noticed that because FPS going down a lot and suffering microstuttering.
What I have done :
- Went into BIOS and checked RPM CPU fan speed it was like 35 RPM with 90ºC IN BIOS, then without doing anything it went to 1400 ~ RPM and then temp went down slowly to 60º C. After that I toggled manual settings for CPU fan, by default it was 0,75x, so I changed it to 2,25x speed/temps but nothing has changed.
- In the picture below you can see all the details and also my CPU is 4 ghz base but somehow it is running at 4,4 without ever doing a OC or touching anything.
So don't know what is the reason or how to fix it. Thanks in advance
What I have done :
