I was having a rough day and played some video games, i had no issues at all. Turned off my computer the usual way, through the shut down option and went to sleep.
The next day i started my computer to finish my project but my monitor was showing no signal.
Tried everything from replugging my video card (checking if its all the way in), testing if my mobo is working and it was in fact working, switching my rams. Tested an old gt 730 and it was all good.
I have an 1050ti OC Gigabyte low profile, theres no 4-6 pin connector and i got a spacer 450w psu.
RAM: 8gbs ddr3
CPU: i5 4690k
MOBO: Asrock H81M-VG4
I got this video card as a christmas present, and all i did was to play valorant with it, which is pretty much a cpu based game. I never overclocked my gpu and didnt think about doing it at all; got the default nvidia control panel settings and the drivers were up to date before showing no signal. I can't switch to my mobo igpu since my monitor doesnt have a vga/dvi slot and the igpu only has vga slots.
Tho, if my 1050ti is in fact dead, how is that even possible? I had not even a single issues through the entire year and use of it. Haven't played gpu based games at all and so on. Is there any way to check if its dead or not; i really dont wanna buy a new gpu to run games in 144+ since the price is outrageous nowadays..
(Tried using it in a different computer and it has the same issue; psu-550w)
RAM: 8gbs ddr3
CPU: i5 4690k
