Artic liquid frezzer II 240mm,about 100$ on amazon right nowI got it working also do you have any recommendations for a 240 aio for the 10700k my friend is using a h60 and it's not doing a very good job it got over 80c when he compressed a file
I have a corsair 850w, he has a EVGA 750wWhat psu's do u guys have?
I just had him update it but haven't been able to check it yet will try again another day I will update this post once i'm able to checkIs his motherboard bios up to date?
I used both pcie slots and used the same cables for the 1080ti and the 970 and the 970 worked fine I'm going to hope the bios update will be the solutionAre you using the same PCIe slot and power cables for each card in his PC? Possible bad port/plug
I got it working thx for the helpI just had him update it but haven't been able to check it yet will try again another day I will update this post once i'm able to check
I got it working also do you have any recommendations for a 240 aio for the 10700k my friend is using a h60 and it's not doing a very good job it got over 80c when he compressed a fileIs his motherboard bios up to date?
Thanks for your helpArtic liquid frezzer II 240mm,about 100$ on amazon right now
