Hello,
Working on this configuration
[=]ASUS 560
[=]NTEL 11600KF
[=]CPU Fan Arctic CO 12
[=]One Back fan
[=]One back top fan
[=]Two rear case fan's
with default setting on* TURBO BOOST (CPU and m are new) causing too much heat. its an upgrade from (ASUS b250m & i7100)
SITUATION
While performing 'easy' task's CPU working on 5-10 % ((3-4.5Ghz) via balanced power plan) which doesn't make any notable heat at 50-60 Celsius. Enough interesting : if via power plan maximum processor power will be set to 99% , it will skip boost and will run maximum at 3.7ghz. As well With in bios Turbo disabled - CPU run's at ~3.9 (pretty similar with turbo enabled with power set on 99%) and heat stays at 50-60 at 100 usage % in render or other software.
OVERALL
So working with CPU intense applications such as ffmpeg or other software, causing CPU to OVERHEAT over 97-100 Celsius in no time (fast quit forcing application reduces back to 50-60 state) which according intel documentation processor should DIE at this temperature.
I want to know how adjust turbo automated CPU frequency without completely disabling it.
[=]ASUS 560
[=]NTEL 11600KF
[=]One Back fan
[=]One back top fan
SITUATION
OVERALL
