I currently have three stock 120mm case fans, one as an air intake, one as an exhaust, and one on the side (that I am considering leaving off). I had noticed that the intake fan was much louder than the others, so I cleaned them and switched them around, and whichever one I had as the intake fan was horribly loud.
The intake was always the only one connected directly to a 3-pin connection on the motherboard, the other two were connected via molex adapters which used the yellow and black which I believe is 12V. I always believed that the less voltage, the quieter it would be?
I was considering something like this: http://www.amazon.co.uk/BitFenix-20cm-Molex-3-Pin-Adapter/dp/B004ULZ2NU/ref=sr_1_15?ie=UTF8&qid=1355346869&sr=8-15 which would make them all 7V, with the assumption that it would make my system quieter, now I have my doubts. How much voltage is the motherboard 3-pin providing?
