144hz GPU for 144hz monitor?
yes it will, no problem, but if it's for gaming, the 144 won't matter if the rig won't even push above 60. but 7850 is a good gpu, but it won't reach >100 on ultra settings like say bf4
I use displayport for 144hz fine i tried to lookup on google displayport hz limit and i couldnt find its limit just the 4k resolution is 60hz but 4k is 4x the resolution of 1080p so i would think it can go more than 144hz ?
i use the same one as his video card i think its slanted one
The G-sync monitors are all 144hz, and they only work on Displayport. Dual Link DVI-D used to only say a max of 120hz, but it also has been used to get 144hz. HDMI is the only one which doesn't. It can't go past 60hz for most GPU/Monitors. Though there is a new HDMI 2.0 spec, it is very new, and nothing supports it yet, for the most part.
