I've gone through a few of the guides on here. I've never built a machine from scratch before, so would be interested in what any of you think of my choices:
Approximate Purchase Date: Within a couple weeks
Budget Range: $1500-$1600 (not including the monitor)
System Usage from Most to Least Important: Gaming, surfing the internet
Are you buying a monitor: Yes
Do you need to buy OS: Yes
Preferred Website(s) for Parts: www.canadacomputers.com, www.shoprbc.com
Parts Preferences: Intel, AMD
Overclocking: Maybe (never tried before, but I might)
SLI or Crossfire: Maybe (not to begin with, maybe down the road)
Your Monitor Resolution: 1920x1200
Additional Notes: Never tried an SSD before, also my first time going with a high-end video card instead of a more middle of the road one, never had a 7200 RPM hard drive, etc. A lot of firsts for me.
And Most Importantly, Why Are You Upgrading: Upgrading from a gaming laptop (ASUS G73J, with ATI mobility HD 5870 card). Have been finding Guild Wars 2 to be sluggish with the settings turned up.
My build I'm considering:
Intel Core i5-3570K Quad-Core Socket LGA1155, 3.4Ghz, 6MB L3 Cache, 22nm (Retail Boxed) Gen3 (BX806237I53570K)
http://www.canadacomputers.com/product_info.php?cPath=4_65&item_id=045425
Gigabyte GA-Z77X-D3H Socket 1155 Intel Z77 Chipset
http://www.canadacomputers.com/product_info.php?cPath=26_722&item_id=052352
Microsoft Windows 7 Home Premium with Service Pack 1 64-Bit
http://www.canadacomputers.com/product_info.php?cPath=530&item_id=037803
Cooler Master Storm Enforcer Mid Tower Case w/ Window
http://www.canadacomputers.com/product_info.php?cPath=6_112&item_id=038223
Corsair Vengeance 16GB (4x4GB) DDR3 1600MHz CL9 DIMMs
http://www.canadacomputers.com/product_info.php?cPath=24_311_312_612&item_id=035074
Samsung 840 Pro Series 256GB 2.5" SATA 6Gb/s Solid State Drive
http://www.canadacomputers.com/product_info.php?cPath=179_1088&item_id=053763
Seagate 7200.12 2TB 7200RPM 64MB 3.5" SATA3 HDD
http://www.shoprbc.com/ca/shop/product_details.php?coid=17427314
OCZ ZT Series 750W Power Supply
http://www.shoprbc.com/ca/shop/product_details.php?coid=17427327
Gigabyte Radeon HD7970 OC 3GB GDDR5 PCI-E Video Card
http://www.shoprbc.com/ca/shop/product_details.php?coid=17427330
This comes in at just under $1500, though I still need to decide on a monitor. I've also been toying with the idea of using two monitors, but am not sure yet about that. Did I forget anything essential? Is there something I chose that you disagree with (and why)?
Thanks.
Thanks.
You might be right.I would not put it past those blood suckers.
Lol!! what a nightmare! I do not even want to think about it.Maybe... i will start looking for a different hobby if that's the case.
