R roobban Reputable Apr 8, 2015 2 0 4,510 Apr 8, 2015 #1 I have 2x4gb 1600mhz memory lying around, is it possible the run them in a motherboard that is compatible to 1066mhz?
Solution S S Samat Apr 8, 2015 roobban : Yes the memories are ddr3 and the motherboard supports ddr3 but in 1066mhz Memory modules should have no problems at working with the lower frequency, you just wont get the full speed the modules support.
S Samat Distinguished Aug 21, 2006 1,274 1 20,465 Apr 8, 2015 #2 If it's of the same memory type as the motherboard supports then yes. Upvote 0 Downvote
R roobban Reputable Apr 8, 2015 2 0 4,510 Apr 8, 2015 #3 Yes the memories are ddr3 and the motherboard supports ddr3 but in 1066mhz Upvote 0 Downvote
kanewolf Titan Moderator May 29, 2013 38,666 3,813 156,790 Apr 8, 2015 #4 You should check what RAM voltages the motherboard supports vs what that RAM expects. Upvote 0 Downvote
S Samat Distinguished Aug 21, 2006 1,274 1 20,465 Apr 8, 2015 Solution #5 roobban : Yes the memories are ddr3 and the motherboard supports ddr3 but in 1066mhz Memory modules should have no problems at working with the lower frequency, you just wont get the full speed the modules support. Upvote 0 Downvote Solution
