1600mhz vs 2000mhz ddr3
Kankfish
Hey all,
Straight to the point:
6gb of 1600mhz ram @ 7-8-7-20
Or, for $10 more, 6gb of 2000mhz @ 9-9-9-24
Both are corsair.
CAS 9 on 2000 isn't slow, and CAS disparity {7-8-7-20} is worst.
I'd need to know (2) things - 1. What MOBO {verify either RAM is compatible}, 2. Both RAM part-number and or links. Also, 2000 MHz RAM only works properly for extreme OC'ing ~ 4+GHz.
Comparison Module #1: Mushkin Redline 996805 6-8-6-24 1600MHz
Comparison Module #2: G.Skill Pi Series 7-8-7-24 1600MHz
Comparison Module #3: Mushkin 998687 8-9-8-24 1866MHz
Comparison Module #4: Corsair Dominator TR3X6G1600C8D 8-8-8-24 1600MHz
Comparison Module #5: Kingston HyperX T1 9-9-9-27 1600MHz
Comparison Module #6: Mushkin Blackline 998677B 7-7-7-20 1333MHz
Comparison Module #7: Patriot Viper II Sector 7 9-9-9-27 1800MHz
I don't know since the price diff is small and your mobo support 2200 mem speed,. But unless you go for heavy overclocking (like using nitrogen or dried-ice pipe) you should stay fine with 1600 low timings.
I would ONLY use the GA-X58A-UD3R "IF" I were building a "Hackintosh" {hacked/homebuilt Apple PC running off Intel MOBO}, otherwise I strongly recommend the ASUS P6X58D-E paired with Corsair Dominator 1600 MHz part-number TR3X6G1600C8D 3x2GB.
First, I do NOT recommend the Gigabyte GA-X58A-UD3R especially if there's an SSD + HDD or in RAID - http://www.tomshardware.com/forum/276715-30-x58a-ud3r-raid-bsod-disk-boot-failure
Second, I recommended the CORSAIR DOMINATOR 6GB (3 x 2GB) DDR3 1600 (PC3 12800) TR3X6G1600C8D - http://www.pccasegear.com/index.php?main_page=product_info&products_id=15459
MOBO replacement, do recommend the ASUS P6X58D-E http://www.pccasegear.com/index.php?main_page=product_info&products_id=14230
In BOTH MOBO's the {TR3X6G1600C8D} is the way to go, it is the SAME RAM in the Graph {above}.
Corsair Tested GA-X58A-UD3R - http://www.corsair.com/configurator/product_results.aspx?id=1362102
Corsair Tested ASUS P6X58D-E- http://www.corsair.com/configurator/product_results.aspx?id=1522755
Good Luck! :)
