1866MHz RAM, Running at 671Mhz?
HardwareSpeccy
22
I recently bought a new computer, Motherboard says it allows
DDR3 - 1066
DDR3 - 1333
DDR3 - 1600
DDR3 - 1866
DDR3 - 2000(OC)
The RAM I bought was Corsair Vengeance 2x4GB's @1866MHz
It should be compatible, but when i run speccy it says its @671MHz (9-9-9-24).
CPU: AMD FX 8350 Black Edition 8 Core Processor 4.00GHz. AM3+
If you built it yourself what you probably did was not realize that the Ram had to be overclocked to reach those MHz it was the same as my Ram but i figured it out luckily before i finished the bios
I have tried manually setting the voltage on both DRAM and CPU/NB, as well as increasing to 1866MHz, and 1600Mhz, both times they failed.
My friend suggested manually changing the timings?
