1st build please help
Nebul0us
44
Going with i3-3225 processor and was wondering what motherboards are most comparable to ASRock Z77 extreme4 for under $105. Preferably ASUS or MSI...
No. ATX. Why did you presume htpc?
Why else you go with a i3-3225 ? The 5 in the end is for the intel hd 4000, the i3-3225 is known for a htpc cpu for it's on die gpu(intel 4000) and lower power consumption.
And for a i3(you can't overclock) you'll be better off with a h77 mobo, also if you don't need the intel hd 4000, just get the i3-3220, same performance(only the on die gpu is different, it has the intel hd 2500).
That said, i don't know what's your needs.
But if you want atx :
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157302
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157304
or if you still want z77 for lower price :
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157297
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130653
I am going with the i3 because it's the best i core for the money right now, and I don't do a lot of gaming. I am going with the 3225 because this build does not have a GPU in it, so I wanted the extra graphics performance that Intel HD 4000 offers. My plan is to upgrade to i7-3770k or equivalent a year or two from now, and add GPU at that time. I figure I can do that for about $100 a year from now. That's why I wanted Z77, because I don't want to have to replace MOBO when I upgrade. Thanks for the suggestions!
