Question 2 new PSU's with a old GPU = problem ; (OLD PSU = NO PROBLEM)
Jun 29, 2024
4
Hi guys, how are you?
I wanted to ask you about a problem I am having.
About a month ago I bought a new power supply to replace my old one. The old one was a Sentey ERP700W-SS. It was working perfectly (despite being 10 years old), but I am in the process of upgrading the GPU (I currently have a GTX 1060, and I plan to buy a RTX 3080ti), so I wanted to upgrade it as well.
The new power supply I bought was a Cooler Master G800 80 Plus Gold ATX. However, when I finally installed it, I started having problems almost instantly.
When I played a more or less demanding game, or when I ran some benchmark test, the screen would go black and the fans inside the case (at least the GPU fans) would start running at full speed. This problem totally disabled the use of the PC, and I had to proceed with a hard reset to get back to normal.
At first I thought that I plugged the cables in wrong, or that it was something to do with some static charge due to having assembled the PC barefoot. However, after assembling and disassembling all the components and cables several times, and tightening all the components (GPU, RAMs) sockets, I was out of options. There was no way to get it to work properly and not get the aforementioned error. As soon as I ran Heaven Benchmark or any game, the screen would turn black and the fans would go crazy.
I finally decided to put the previous power supply back in (Sentey ERP700-SS) and, to my surprise, everything worked like a charm. Games ran perfect, and the Heaven Benchmark performed flawlessly.
I was really concerned that the new power supply might have been faulty from the factory, so I put it back in... and the problem reappeared. In one instance the new power supply managed to work fine, but as soon as I moved the cabinet sideways, the problem was triggered. I concluded, unfortunately, that the power supply was defective, and asked for a refund (perhaps there was a loose component inside).
After 20 days, my money was refunded, and I decided to buy a different source. A new Thermaltake Toughpower GF1 850w Gold Modular. I had to put more money, but I thought it was worth it.
After installing it and being able to run the PC, the first thing I did was to run Heaven Benchmark. It worked perfectly! ... However, after a couple of days of use, and while watching a YouTube video.... BANG!!! The previous problem reappeared. Black screen + fans at maximum = hard reset.
Worried, I went back to run Heaven.... It worked great. I tested it several times, and this time, just in case, I decided to underclock the GPU (maybe it was a GPU problem, I flatly refused to accept that 2 NEW PSU's were defective).
Finally we come to today. With the new PSU installed and the GPU underclocked, I was watching a YouTube video at 1440p, and suddenly... the problem again.
GOD, I don't know what to do anymore.
Does anyone have any idea what could be going wrong?
I share the rest of the technical specifications of my PC:
New PSU: Thermaltake Toughpower Gf1 850w Gold Modular
Motherboard: A320 PRO-VH (MS - 7C52)
GPU: Nvidia GeForce GTX 1060 6GB
CPU: AMD Ryzen 5 3600
RAM: 1 x 16GB DDR4
STORE : 1 x SSD 1TB and 1 x HDD 1TB
EXTRA DATA - Old PSU: Sentey ERP700-SS (10 years old, and that does not generate problems)
Thanks in advance to anyone who responds. XXXX [Moderator note: deleted apparent link to msi account login.]
I would start by looking in Reliabillity History/Monitor and Event Viewer for error codes, warnings, or even informational events that were captured just before or at the time of the problem's appearance.
Reliability History presents a time line format that may reveal some pattern with respect to problems appearing and dissapearing.
Event Viewer requires more time and effort to navigate and understand. However there is no need to rush through it and you can take your time to investigate details etc. as necessary.
One immediate question: you always used only the cables that came with any given PSU - correct?
My sense is that something is loose or cracked and, one way or another, causing some short.
More information needed.
Hi. Thanks for replying!!!
Yes, it is my first modular PSU, and I am using the cables that came with it (they are not meshed).
In the Reliability History I found nothing relevant except a banner at the same time of the problem that "Windows did not shut down properly", with no additional information.
On the other hand, I just checked as you said, and found in the Event Viewer these two errors:
Do they mean anything?
PS: I think I failed to clarify one thing, which I don't know if it's relevant... I'm using an old monitor with low resolution (something like 1366x756). I don't know if it's relevant, but the last time the problem appeared I was watching a 1440p video.
edit: I had uploaded the wrong image of the error.
Black screen and fans to maximum is a power problem the vast majority of the time. I find it highly unlikely that the problem is with either one of the power supplies you've gotten.
The only time I've had this occur was when I didn't get the 2 pin part of the 6+2 pin connector in correctly so bumping the case would cause a disruption of power.
Is it possible that the connector on the video card has been warped in some fashion?
Mmm maybe the GPU connector is deformed, as you say. The thing is, if that's the case, why does it work perfectly with the old PSU?
Today the problem occurred again while I was using Opera. I was not touching or moving the computer cabinet at the time of the problem. The GPU was underclocked, and I had recently finished a game of Deep Rock Galactic (I had no problem). This problem is more than random, it doesn't seem to be fixable, but I don't think it's the PSU.
I noticed the following event in the event viewer.
This is the XML view:
Nombre de registro:System
Origen: Microsoft-Windows-Kernel-Power
Fecha: 3/7/2024 23:33:05
Id. del evento:41
Categoría de la tarea: (63)
Nivel: Crítico
Palabras clave: (70368744177664),(2)
Usuario: SYSTEM
Equipo: DESKTOP-LLBI4ED
Descripción:
Se reinició el sistema sin apagarlo limpiamente primero. Este error puede producirse si el sistema dejó de responder, se bloqueó o se interrumpió el suministro eléctrico de forma inesperada.
XML de evento:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" />
<EventID>41</EventID>
<Version>8</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2024-07-04T02:33:05.0860719Z" />
<EventRecordID>294715</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>DESKTOP-LLBI4ED</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">9</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
<Data Name="BugcheckInfoFromEFI">false</Data>
<Data Name="CheckpointStatus">0</Data>
<Data Name="CsEntryScenarioInstanceIdV2">0</Data>
<Data Name="LongPowerButtonPressDetected">false</Data>
</EventData>
</Event>
And this is the descriptive view:
-System
-Provider
[ Name]Microsoft-Windows-Kernel-Power
[ Guid]{331c3b3a-2005-44c2-ac5e-77220c37d6b4}
EventID41
Version8
Level1
Task63
Opcode0
Keywords0x8000400000000002
-TimeCreated
[ SystemTime]2024-07-04T02:33:05.0860719Z
EventRecordID294715
Correlation
-Execution
[ ProcessID]4
[ ThreadID]8
ChannelSystem
ComputerDESKTOP-LLBI4ED
-Security
[ UserID]S-1-5-18
-EventData
BugcheckCode0
BugcheckParameter10x0
BugcheckParameter20x0
BugcheckParameter30x0
BugcheckParameter40x0
SleepInProgress0
PowerButtonTimestamp0
BootAppStatus0
Checkpoint0
ConnectedStandbyInProgressfalse
SystemSleepTransitionsToOn9
CsEntryScenarioInstanceId0
BugcheckInfoFromEFIfalse
CheckpointStatus0
CsEntryScenarioInstanceIdV20
LongPowerButtonPressDetectedfalse
And if I do the same with the other event with origin "Kernel-Power" but classified as "information", I get the following:
Id. del evento:172
Categoría de la tarea: (203)
Nivel: Información
Palabras clave: (1024),(4)
Usuario: SYSTEM
Descripción:
Estado de conectividad en modo de espera: Disconnected. Motivo: NIC compliance
XML de evento:
<System>
<EventID>172</EventID>
<Version>0</Version>
<Level>4</Level>
<Task>203</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000404</Keywords>
<TimeCreated SystemTime="2024-07-04T02:33:05.0863891Z" />
<EventRecordID>294716</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="320" />
</System>
<EventData>
<Data Name="State">2</Data>
<Data Name="Reason">6</Data>
</EventData>
</Event>
-System
-Provider
EventID172
Version0
Level4
Task203
Opcode0
Keywords0x8000000000000404
-TimeCreated
[ SystemTime]2024-07-04T02:33:05.0863891Z
EventRecordID294716
Correlation
-Execution
[ ProcessID]4
[ ThreadID]320
ChannelSystem
-Security
[ UserID]S-1-5-18
-EventData
State2
Reason6
Well... I hope this extra data will contribute to the diagnosis. I'm SURE that more than one of you who is seeing this post has or had the same problem, and more than sure that you couldn't solve it. Let's see if together we can find the solution, so it is a reference for future people in the same solution.
