G Gadrad Gad Honorable May 14, 2013 6 0 10,510 Jul 12, 2013 #1 I have (2) 2pin molex fans and I want to buy two more but I only have 2 molex connectors. If I powered 2 fans with 1 connector would the 2 fans draw as much power as the molex connector provides?
Solution clutchc Jul 12, 2013 You can string quite a few fans on a single Molex. Fans are very low amperage,usually in the 1.x Amp range. You are good to go.
clutchc Titan Ambassador Apr 22, 2009 43,153 409 131,790 Jul 12, 2013 Solution #2 You can string quite a few fans on a single Molex. Fans are very low amperage,usually in the 1.x Amp range. You are good to go. Upvote 0 Downvote Solution
