Question 2 year long problem, AMD.................
Mar 30, 2022
33
For 2 years eveer since i built my PC, ive had problems, mainly playing games, BSOD, stutters, crashing, tho i have rectified most of the problems, dont really get any BSOD anymore etc, but it seems that whenever i play games, i get about 5-20 minute play time and then it will just freeze and hit desktop, some games get critical error pop up depending on which game, some games it has no error pop up, i've done everything you could possibly think of to fix this <MOD EDIT profanity removed> mess, ive rolled back to numerous drivers, ive installed fresh versions of windows multiple times, my HDD and SDD are in good health using CrystalDisk etc, i've ran MemTest for over 18 hours no errors, i have the latest Bios regarding the technology that my computer has, latest windows update, latest GPU driver, ive gone into the Bios to change the PCIe from Gen 4 to Gen 3, problem is still there, I can go all day listing the things ive tried, this is taxing.
OS: Windows 10 Home
GPU: 5700xt
CPU: 3700x
MO: x570 Gigabyte Auros
RAM: Corsair Veng LPX 32Gb 2x16GB DDR4-3200
Cooler: Noctua NH-D15
SSD: 2x Samsung 860 Evo 1TB
M.2: WD Black 500gb
PSU: Corsair RMx 750w
Like I said most of the problems that this computer has had since day 1 has been fixed overtime, but still currently when i try to play most games i own, i.e Warzone, Dota 2, World fo Warships, Tanks etc it will perform, good temps, good usage via task manager and then it will just hit desktop most time no error pop up, like today im keeping keen eye while i test the situation on warzone, everything looking great, then the GPU usage will just decide to hit 0% when the game will just freeze, the computer is still running perfectly fine i can use my mouse on other tab while this happens but the game is locked, ive looked all over online and i cant seem to find people will similar problem, there was i time during the 2 years where this problem didnt exist for a few months tbf but then it just came back again, where i coudl play any game anytime no problem, but yeah, now if i play warzone for instance it would just freeze and hit desktop, plz help.
Bios version: F36
Driver: AMD 22.3.1
X.M.P is also off, for some reasion ive always had trouble with it on.
pagefile is needed even if you have plenty of ram available..windows stores in there some kernel stuffs so it can record bsod from there when PC crashes
those eventviewer errors are all same? app crashing with 0xc0000005 code?
that is access violation error which is mostly caused by faulty ram, corrupted files, or messed up pc configuration
do some stress testing, memtest doesnt stress test ram, it just tests some random patterns which wont heat up your ram
it creates a file called stress.txt in the folder the program is installed in, that shows results.
Its unlikely to name the problem part but it might show a clue
For instance, if you find rounding errors, you can raise voltage on ram in bios to remove rounding.
we won't know until you run it. run it overnight since you can't use PC while you asleep.
