Question 2200g and RX570 display problem
Feb 8, 2020
Hello, in the beginning I built (First PC) and APU system with Ryzen 3 2200g then saved up for a GPU and finally got on hand on a RX570.
Plugged in the GPU and restarted PC with HDMI connected to GPU. GPU led blinked but no display on the monitor. I then unplug the HDMI and connected to the MoBo’s HDMI. There’s a display output.
PC Spec
CPU: Ryzen 3 2200g
GPU: Asus ROG Strix RX570 4gb
MoBo: Gigabyte B450m S2H
PSU: Thermaltake Litepower 450W
Ram: HyperX Fury 4gb DDR4 2666Mhz
Storage: Kingston A400 240gb
If you plugged the power connector correctly on the GPU and it's not working then don't go further than what I will say below.
https://www.gamingscan.com/psu-hierarchy/
TIER 6 - Thermaltake Litepower Series - Non-Rated - 350, 400, 450, 500, 550, 650 Watts
https://linustechtips.com/main/topic/1116640-psu-tier-list-40/
Tier E - Potentially dangerous in multiple scenarios
That PSU is a low quality PSU not even rated. For that 570 you need a minimum of 450 Watts which you have but you need a good quality 450 Watts.
You could try the RX570 in another system to see if it works or you can buy another PSU.
I have exactly the same gpu and psu in my system, only difference is I have a core i5 cpu, different mobo, and 12g ram.
My setup works. I have one question for you. The lite power only has 6 pin pcie connector. The asus rx 570 needs 8 pin arrangement. How did you entertain that…?
Did you check before saying it only has 6 pin PCIe connector(s)?
https://www.thermaltake.com/litepower-450w.html
PCI-E 6+2PIN6+2pin PCI-E Connector x 2
If you have the same PSU how come you did not see the +2pin on each 6pin?
