i have a this motherboard
http://www.ebay.co.uk/itm/360440791705?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_2962wt_1139
you can check the link for the specification and my problem is that i have a 20 pin power supply and because the motherboard requires a 24 pin ATX power connector might i be able to use this ADAPTER
http://www.ebay.co.uk/itm/150434616002?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_1688wt_905
and i will be having a dedicated graphics card, please visit the link for the detail because its too much to put on
http://www.ebay.co.uk/itm/320865689318?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_813wt_1185
so will i be able to use the adapter and not damage my graphic card or the motherboard?
thank you
thank you
