Question 27" Triple Monitor Stand or wall mount that works with curved displays
Shushki
6
Hi, I am looking to purchase new monitors that have to meet the following criteria;
- $550 or less for all three monitors
-27in and 1920x1080
-5ms or less response time
-60Hz or more refresh rate
-Curved
-VESA Mountable
And I have found these;
For the middle display (Main gaming display): https://www.amazon.com/gp/product/B07N6ZBCVY/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&psc=1
And for the two sides (Productivity displays): https://www.amazon.com/gp/product/B071JJ8V4S/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
I chose these because I wanted 144Hz for the gaming display with the 3ms response time and two side ones that I could use for productivity so they didn't necessarily have to be 144Hz or have a fast response time.
My main issue with this plan is that the side monitors have a different hight than the main monitor and this would bug me as I want all of them to line up together. So my only thought to rectify this issue is to get a mount for the three monitors. I'm not sure if traditional Tripple Monitor Mounts support curved displays or if they would look weird and not line up properly.
Does anyone have any suggestions on other monitors or mounts that I could use?
Cheers.
It appears the center monitor will sit a little higher on an in-line VESA mount than the other two, so if you get a triple monitor stand, you'll need one that allows the center monitor to be lowered to match the height of the other two. Those monitors all use standard VESA mounting hole patterns, so the mount doesn't have to be specially made for curved monitors. Just make sure to use one with flexible arms, because a mount with a long solid arm wouldn't give you enough flexibility for a smooth curve across the monitors.
