2X 2GB stick (4gb) plus onw 4gb stick (single chanel) help
jessereed206
4
my pc normally has 2 2gb sticks. my pc can max out 8gb total. so i went to best buy and bought a 4gb stick (single) now my pc crashes allot and blue screens me. any help? thanks.
(the 2gb sticks are paired)
Go into the BIOS and find DRAM voltage in the advanced page and manually change it to 1.55 (unless this is a prebuilt computer in which casethere's a good possibility that the BIOS is locked
jessereed206
4
its already too late...... i cant return it. do you know how to make it work fine without crashing?
killerhurtalot
1,207
Uh.... what's the specs of the ram sticks? If they're similar, you might be able to fudge it with changes to the voltage and timing.... (unless you're on a pre-built PC, then you're kind of screwed since they lock all that down)
jessereed206
4
the 4gb stick specs
Type DDR3
Size 4096 MBytes
Manufacturer PNY Electronics
Max Bandwidth PC3-10700 (667 MHz)
Part Number 64C0MHHHJ-HS
Serial Number 584A0000
Week/year 34 / 13
the 2gb specs
Type DDR3
Size 2048 MBytes
Manufacturer Unknown
Part Number GU512303EP0202
Week/year 33 / 10
all sticks running at 1.50v
