Question 2x4pin cpu fan power connector
Apr 18, 2020
8
4
15
I have a motherboard “biostar z170t” comes with 2x4pin cpu fan header named “cpu_fan1” & “cpu_fan2” and i have “V8 gts” cpu cooler and comes with two fans and each fan comes with 4pin connector also. should i connect them on 1 cpu header using y splitter or should i connect them separately? Im asking for which is better, thank you.
Reactions: vcc98554vn
Apr 18, 2020
8
4
15
Ahh okey. Anyway can you tell me if these two cpu fan header will run my two cpu fan at same speed and voltage? are they will synchronized as well?
Apr 18, 2020
8
4
15
Thank you, Is it true that 1 cpufan header max output of 1A in most motherboard? If that is the case, anyway can you explain why it will reduced the performance of the 2 cpu fans while attaching it to 1cpu header Using Y splitter since my 2cpu fan controller consumes 0.31A only?
vcc98554vn
Great
Apr 18, 2020
146
19
95
maybe it will have some voltage drop with full speed fan but i think if it have enough header you should connect each to each
Reactions: Trinity88
