Just to clarify I'm quite an OC noob here.
My Setup:
GPU: 2x AMD Radeon 6970 2GB
CPU: Core i5 2500 (stock cooler, no OC)
MB: Asus P8P67 Pro
8GB RAM
My last question was trying to figure out if my CPU or GPU was bottlenecking bf3.
http://www.tomshardware.co.uk/forum/348427-15-could-2500-bottlenecking-6970
Despite the fact that lower graphics settings increases frame rates, I was getting nowhere near the rates described in this review:
http://www.tomshardware.com/reviews/radeon-hd-7970-benchmark-tahiti-gcn,3104-7.html
Because 2x6970 is better than a 6990, and the only difference between my setup and their test setup is that he has an overclocked CPU, I think my CPU must be the issue.
Assuming that is correct, I should buy an unlocked CPU and better cooler and overclock it to see if I get better results.
Before I do this, I was wondering if there's any way to pull off a slight overclock on the 2500 (again not the 2500k) with the stock cooler that would be visible to me in bf3.
As an aside, I am wondering why turbo boost was disabled for that review http://www.tomshardware.com/reviews/radeon-hd-7970-benchmark-tahiti-gcn,3104-7.html Is there any way that is causing my CPU problems?
Lastly, I am wondering if there is any way I am being bottlenecked by the CPU in battlefield 3 (as most evidence seems to suggest) while my CPU usage graph looks like this (far under 100%):
My Setup:
MB: Asus P8P67 Pro
8GB RAM
