Hello friends,
I recently bought my 3rd monitor. But I couldn't manage to get all three of them to work at the same time. 2 monitors work but I have to disable the other one to activate the 3rd one. I can get images from all monitors but more than 2 are not active at the same time.
- I use AMD HD 6850 as a graphics card.
- My 2 monitors only have VGA inputs.
- My 1 monitor has VGA + DVI-D inputs.
I am trying to transfer from the graphics card as follows;
- Passive converter from DVI to VGA.
- Active converter from HDMI to VGA.
- Active converter from Display Port to VGA. (I am not sure if it is active but I will leave the sample image below)
I have been researching for days but I could not reach a conclusion. I am only considering the possibility that the DP to VGA adapter is not active. Thank you in advance for your help.
1st adapter: https://ibb.co/P6qYdSf
2nd adapter: https://ibb.co/TPQ1CzT
3rd adapter: https://ibb.co/SRc9P4s
