Later edit: updating the BIOS firmware to the latest version (F65b) fortunately solved the first issue: now the HDD is recognized when connected to the SATA port.
Heya
So I got a second-hand computer (I'll write the specs at the end) and I installed a fresh copy of Windows 10 and after a couple of days I encountered/noticed 3 weird issues with this system and they might be related somehow, or maybe not:
1. The main drive in this computer is a Patriot Burst SSD and I wanted to add a secondary drive, a Seagate Momentus HDD. I connected this HDD on different SATA ports (I have 6 ports) , I tried different PSU connectors, I bought new SATA cables, but whatever I do the computer doesn't recognize this drive. It doesn't show up in BIOS (and obviously it doesn't show up in Windows as well). By the way, the BIOS firmware is up to date (v. F63b). Later edit: actually the BIOS was not up to date, the newest version is F65b.
BUT if I put this drive in a USB3 enclosure then it shows up and it works just fine, so there's nothing wrong with the drive. Also, if I connect another SSD on any SATA port, that SSD is recognized and it works just fine, so it seems that the SATA ports are not the issue. In other words: both the SSD and the HDD are recognized when connected thru the USB enclosure but only the SSD is recognized when connected thru the SATA ports. Very weird.
2. I'm using a TP-link USB wi-fi adapter to connect to the internet. Normally I have this adapter inserted in one of the two USB2 ports at the front of the case and it works just fine. BUT if I connect an external drive (or that USB enclosure containing either the SSD or the HDD) to the USB3 port also at the front of the case then the internet connection is lost (the computer is still connected to the wifi network but without internet access, and if I try to disconnect and reconnect to the wifi network I get some message saying that it cannot connect to the network). If I then disconnect the external drive the internet access resumes and works just fine. Also, if I connect the TP-link wi-fi adapter to one of the USB ports at the back of the case I don't get this issue and i have internet access even with the external drive connected to the front USB port. In other words: I don't have internet access when both the wifi adapter and the external drive are connected to he front USB ports. Again, very weird.
3. A couple of days ago I noticed a strange behavior of the CPU temperature, and I'm pretty sure this didn't happen before: the temperature jumps suddenly to a higher value then drops steadily to a lower value, then suddenly jumps again, and so on. The temperature graph looks exactly like a sawtooth:
This is the CPU temperature graph when the computer is idle (around 0-1% CPU load). Those sudden spikes happen at a 10-15 seconds interval while the CPU fan stays constantly at the minimum speed (around 870rpm). As far as I know it should be impossible for the temperature of the CPU to jump suddenly (in a couple milliseconds) from 35 to 45 degrees. Really weird, isn't it? And what's even stranger is the behavior of the temperature readings when the CPU is not at idle. It looks like this:
As you can see, when the CPU load is constantly around 15% (and the CPU fan stays constantly at around 1050rpm) those weird spikes appear way more randomly, sometimes there's almost a minute between two adjacent spikes and sometimes 10 seconds.
So, what do you guys reckon?
Here are the specs:
GIGABYTE B450 GAMING X
AMD Ryzen 5 1600X
Sapphire RX 570 Pulse ITX Mini 4GB
2x8GB DDR4 A-Data SDRAM
Patriot Burst 480GB SSD
(Later edit) nJoy Titan 600 600W PSU
Windows 10 Pro 22H2 64bit
Cheers!
Heya
Here are the specs:
AMD Ryzen 5 1600X
Cheers!
