Building an overkill dual pc water cooled setup kind of going after the Orion 8pack setup. Background... I’ve built several hundred gpu mining rigs but none with custom water cooling. I may be going to far with four water loops as there are two radiators slammed up against each other. Open to advice on any of it possibly did things wrong. The 4th radiator is an odd ball because I originally wanted it to match but realized watercool doesn’t make that size. Decided to run the top radiator down to the bottom section and bulkhead fitting up. Not sure on exact routing of the tubes yet trying to make it look good and function properly. Any ideas on the cooling system would be greatly appreciated.
Phanteks enthoo elite
Evga 1600 t2 with dual mb splitter
Main system
Rampage vi extreme
I9 7980xe binned ocuk
3 titan XP’s in sli
Corsair dominator platinum 128 gb
Intel optane ssd 900p
Asus hyper m.2 x16 and intel vroc
4-samsung 960 pro 2tb
samsung 860 pro 2.5 4tb
2 Seagate barracuda pro 12tb
Ekwb blocks
Secondary
Asus z370i gaming
I7 8700k
Titan V
Corsair dominator platinum 32gb
1-Samsung 960 pro 1tb
1-Samsung 860 pro 1tb
seagate ironwolf 10tb
2-seagate barracuda pro 12tb
Ekwb blocks
Cooling system
Aquero lt controller
Watercool radiators 1-360 2-480
Alphacool 240
Bitspower fittings
4 phantek reservoirs
4 ddc pumps
16 Noctua nf-f12
3 noctua nf-a14
Not sure on coolant yet
Main system
Rampage vi extreme
3 titan XP’s in sli
Ekwb blocks
Secondary
Asus z370i gaming
I7 8700k
Titan V
Ekwb blocks
Cooling system
Alphacool 240
Bitspower fittings
4 ddc pumps
16 Noctua nf-f12
3 noctua nf-a14
