Hi, this question MIGHT have been answered already, but i didn't find any, so I am asking it now.
I will be buying 3200g with the stock Wraith Stealth cooler; it will be at full load mostly since I will be using the iGPU, and its suitable for me to play MC with shaders, PUBG lite, Gta v and some other games over 30 fps.
Does the Wraith Stealth have cooling issues?
Is it good enough in cooling for 1 hour straight on full load?
Should I get an aftermarket cooler(if yes, I might be getting a Cooler Master T200. Is it good enough?)?
Does it go over 70C temps on full load?
In case the specs are needed, here it is:
A320 A pro max from msi
2x4gb ram GeIL 2666mhz
200 watts psu
1 intake and exhaust fan in the casing
1tb sata HDD and 240 gb M.2 SSD.
My area is usually 30+ C, if that helps
200 watts psu
