[SOLVED] 3600Mhz memory b450 aorus elite w/ r7 2700x
5leadgaming
28
I have recent bought 3600Mhz memory and it simple will not run at 3600Mhz with both sticks, its CMK16GX4M2D3600C18 2x8gb 3600Mhz RAM
My specs are as follows Ryzen 7 2700x, Aorus B450 Elite, RX 6700 XT, I have x2 3tb hdd's with a 120gb SSD and x1 120gb m.2 nvme drive.
I have 3000Mhz memory which works, but not on XMP profile and works fine at 3000Mhz when set manually, this 3600 Mhz sticks don't work at all on XMP profile and BSOD every single bootup, When set to 3600 Mhz manually with 1.35v, the same thing occurs. The XMP profile works on 1 stick of ram in the 2nd slot of my motherboard but not the 1st one, Could this be my motherboard being the issue?
Thanks to ANYONE who can help, this is quite frustrating to someone who doesn't know about memory timings and all that and relies on the XMP profile working and guides >_<
The motherboard/CPU are not compatible with that memory according to the memory QVL. It will likely run at a lower speed and tighter timings based upon some other sets that do appear on the list.
You can contact Corsair support for their best recommendation to get what you can out of it.
