[SOLVED] 38MB/s Write speeds with SU630 SSD? PLZ HELP!!!
andyanderson
Commendable
Jul 1, 2020
60
4
1,545
just built new pc, spec = A12-9800e, MSi A320m A pro, 8GB DR4 Gammix D10 3000Mz stick, Cylon 500w, With ADATA SU630 240GB Drive.
I first benched it with novabench yesterday and result was = write 419mb, read 420mb. but now when i use same or even crystal disk mark i get 38mb/s.
also copied over gears 5 from backup hard drive, at a painfully slow 20/38mb/s ... it then took 10 mins to load up game menu.
PLZ help, Why has this drive all of a sudden slowed down?? any ideas ppl. TRIM is enabled used the cmd method "0" to check .
plz help soon
Copying from an HDD, you get HDD read speed. No more.
Please show us a screencap of the CDM window.
This also sounds like it's over USB 2.0, which would cap the speeds even worse.
no idea how to post image here, it says "0" tho 100%.
the second hard drive is fast-ish toshiba sata3 32mb cache etc. usually copies at 110mb+/-. with other ssds. connected to sata port 2.
i build and sell pcs all the time, usually buy patriot burst or gigabye ssds, but they never slow down this much this quickly.
is su630 a lemon?
plz help soon
Device manager....disk....policy.
Enable write caching.
Run this......Speccy - Free Download
Now read this and post a link..........Speccy...publish
