3rd monitor problems
th3greenroom
Hello, I've an Asus P8Z68-V Pro Motherboard, 2 Acer 24inch monitors and a Benq 19inch. All monitors work fine from my graphics card, although when I plug any into the motherboard dvi and vga ports none work.
In the display settings when I try to apply the 3rd screen it says"display settings can not be saved"
Any help is greatly appreaciated, cheers
Thanks, I take it that your saying my dvi and vga on my motherboard are disabled because Im using the dvi ports from the graphics cards?
If so, what are my options for a third screen?
