I am looking into setting up 4 monitors on my desktop mainly for work purposes. I do game a little, but a 24" is more than enough for me, my main need comes from my job, which causes me to have to tab between Photoshop, 3 different web browsers, Programmer's Notepad, SCP/FTP programs, Email/instant messenger, MS Office, and other various programs.
My graphics card is an EVGA GTX 560, which is currently running 2 monitors. If I were to buy a 2nd 560 (or upgrade to a 580 for the gaming monitor and run 2 others off the 560), would it be as simple as plugging it into the mobo and hooking up the 3rd and 4th monitors? Below are my system specs, though I am sure my system can handle it.
ASUS Crosshair Formula V AMD 990FX
AMD Phenom II X4 975 Black Edition Deneb 3.6GHz
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM
CORSAIR Gaming Series GS800 800W ATX12V v2.3 SLI Ready CrossFire Ready 80 PLUS Certified Active PFC High Performance Power Supply
EVGA 01G-P3-1460-KR GeForce GTX 560 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
My mobo can run 2 pci-e 2.0 x16 cards (3 at x16, x8, x8), and my PSU is overpowered for what I have right now. So my concern is less about can my system handle it, and more with the actual logistics. Do I need another video with the same chipset as mine, or different? Are there any bios settings or steps I need to take to run 2 gpus? And should I feel the need would expanding to 6 monitors be the same as going from 2 to 4?
