Hey guys, I know there are tons of these out there and I'm generally not one to post aimlessly on forums. But recently some strange things have been happening. I have a few ideas, but I'd rather delegate it to more experienced people than I.
I have a P55 based system (Gigabyte P55A-UD4P) on a Corsair CMPSU-650TX. It's been perfectly stable for 4 months, but about a two weeks ago something interesting happens.
PROBLEM
When I boot up my computer, it goes through POST and Windows loads fine. Right at the login screen, however, the computer immediately restarts. Then it POSTs again, ending up with the "Windows did not shut down properly"... blah blah. This will loop over and over if you let it. (It will always restart after the Windows login screen shows up for 3-4 seconds. Never before.)
TEMPORARY SOLUTION
I find that if I:
1) Turn off the computer
2) Reach behind the case to turn off the power supply.
3) Press the power button on the case (to drain excess off- does this do anything by the way?)
4) Switch the power supply back on
Everything will be normal again once I turn on the computer.
DETAILS
Cooler Master Storm Scout
Cooler Master Hyper 212 Plus
Corsair CMPSU-650TX
Gigabyte GA-P55A-UD4P
Intel Core i5 750 (@3.8GHz- 20x190blck)
8GB (4x2GB) G.SKILL Ripjaws 1600 DDR3 (@1520MHz, 7-7-7-20-1T, 1.5V)
Gigabyte GTX 460 1GB (@ 815MHz/ 1630MHz)
ASUS Xonar DX
I do hear a click when I boot up. I'm not sure what this noise is, but it happens when the bootup is normal as well.
Recent hardware changes (~1 month)- Added Xonar DX, GTX 460, 2x2GB RAM.
I know it's alot to take in. Just hoping someone can help nudge me in the right direction. Or if this is a sign of impeding doom.
I appreciate it!
PROBLEM
TEMPORARY SOLUTION
I find that if I:
DETAILS
Corsair CMPSU-650TX
ASUS Xonar DX
I appreciate it!
