[SOLVED] 4 pin RGB fan on 3 pin Motherboard?
If you turn to page 1-17 in your motherboard manual, you have a 4pin RGB header, labelled as RGB_Header1 and RGB_Header2 respectively. Your motherboard doesn't have a 3 pin ARGB header. Are you referring to the 3pin fan header? If so, the board is populated with 6x 4pin PWM fan headers.
As for your question with the two products listed above, you cannot work with an ARGB device off of an RGB header. You will need an ARGB controller like this one made by Coolermaster.
Alright, got it mixed up then, thanks for referring me to the coolermaster product to get around that issue.
Thanks
