440 chipset and hard drive limitation
G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.storage,alt.comp.periphs.mainboard.gigabyte,alt.comp.periphs.mainboard.giga-byte (More info?)
Got a note from Gigabyte tech support saying that their old GA-6BXE
motherboard does not support hard drives larger than 75 GB because
of a limitation in the 440 BX chipset which it uses.
Is this actually true? I have not come across a 75 GB limit.
Mark
BTW the mobo uses the "Intel 82440 BX AGPset" and "iTE 8671 I/Oset"
G
Guest
Guest
No, it isn't true and Gigabyte knows this!
I have a Gigabyte GA6BXD running, also with 440BX chipset and it runs
with my Samsung SP1614N (160GB) very well.
But You should ensure, that Your OS can handle such drives. For
Windows XP I gues You have to install the ServicePack 1. Don't know
with W2K.
I'm pretty sure, that Your Mobo will support the drive, too, also
there is only 136GB written in the bios like it is done in my bios,
too.
BUT: The BX-chipset isn't very fast for current drives. UDMA33 is much
to less to let modern drives perform well.
Moritz
Dave
2,727
Highpoint Rocket 133 dual-channel IDE controller: $30. Can be flashed for
RAID. RAID 0 for thirty bucks, anyone?
"Mark M" <MarkM_csiphsCANT_RECEIVE_MAIL@yahoo.co.uk> wrote in message
news:94C1A2DB512A63A75@130.133.1.4...
> Mark
G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.storage (More info?)
On Mon, 05 Apr 2004 02:21:41 GMT, "Dave" <whyigetnospam@here.org>
How is it flashed? URL?
G
Guest
Guest
I have 2 servers based on GA-6BXDS running 120GB IDEs perfectly.
G
Guest
Guest
>> GA-6BXE motherboard does not support hard drives larger than
>> 75 GB because of a limitation in the 440 BX chipset which it
>> uses.
> perfectly.
Is the operating system overcoming the barrier for you?
I need to work in something like DOS to do partition copying so the
OS is not likely to be a workaround in my case.
Have you had to update the BIOS? If so then to what version?
G
Guest
Guest
news:94C286B4F37483A75@130.133.1.4...
> > perfectly.
There is no such thing as a 75GB barrier. Most 440BX will do 135GB, ancient
ones will hang over 32GB.
G
Guest
Guest
Try using a hard disk manager / diagnostic tool.
Download from hard drive manufacturer site.
Some offer drive tests as well.
HTH,
John7
"Eric Gisin" <ericgisin@graffiti.net> wrote in message
news:c4rqpe0eok@enews3.newsguy.com...
> > > perfectly.
ancient
G
Guest
Guest
> >> uses.
> > perfectly.
> 1) Is the operating system overcoming the barrier for you?
> 2) I need to work in something like DOS to do partition copying so the
> 3) Have you had to update the BIOS? If so then to what version?
1) No
2) One of the drives was partitioned and formatted in FAT32 (using a Win98
boot floppy) because Norton Ghost versions prior to 2003 could not write to
NTFS partitions.
3) Yes, its F1 now.
G
Guest
Guest
>> >> old GA-6BXE motherboard does not support hard drives
>> >> larger than 75 GB because of a limitation in the 440 BX
>> >> limit.
>> > perfectly.
>> copying so the OS is not likely to be a workaround in my
>> case.
>> version?
> 1) No
> (using a Win98 boot floppy) because Norton Ghost versions
> prior to 2003 could not write to NTFS partitions.
> 3) Yes, its F1 now.
Seems that something is wrong with the Gigabyte site then. It
talks of version F2 of the BIOS update permitting access to disks
larger than 75 GB.
By implication version F1 can not do this. In fact this page
suggests that the whole purpose of version F2 is to provide 75GB
support.
http://tw.giga-byte.com/Motherboard/Support/BIOS/BIOS_GA-6BXE.htm
G
Guest
Guest
"Mark M" <MarkM_csiphsCANT_RECEIVE_MAIL@yahoo.co.uk> wrote in message news:94C1A2DB512A63A75@130.133.1.4
No, and you know that very well.
See?!
> Mark
G
Guest
Guest
news:94C344943FFD3A75@130.133.1.4...
> > 3) Yes, its F1 now.
> larger than 75 GB.
> support.
That's for your mobo, my one's here:
http://tw.giga-byte.com/Motherboard/Support/BIOS/BIOS_GA-6BXDS.htm
That 75GB limit is strange. Neither a whole binary or decimal representation
of capacity. The limits were 8GB binary (24 bit LBA), 32GB (Award BIOS),
64GB (68.72 decimal) (FDISK) and 128GB (137 decimal) (28 bit extended LBA).
G
Guest
Guest
>> uses.
I do not know everything, Folkert! :)
In fact I do not know all the spec of the 440BX chipset so it may
be that there is a limitation the 440BX has separately from the LBA
addressing limitation.
Certainly that is what Gigabyte Tech Support seem to be telling me
in emails. And that is a possible interpretation of this:
Can you read the description for version F2?
I am assuming, perhaps wrongly, that Gigabyte knows more about
their motherboards than I do. It is confusing. Your ejaculations
do not help. :)
> See?!
EWr, what does that prove? It shos that my limited experience in
these matters has not encountered this before. I have not seen
China but that does not mean it does not exist. Heh!
G
Guest
Guest
news:94C482717F4A3A75@130.133.1.4...
> >> uses.
> do not help. :)
Here is everything you need to know about the 440BX chipset:
http://developer.intel.com/design/chipsets/datashts/index.htm
There is a lot of information, so hopefully you will be able to quickly find
what you're looking for. Good luck.
Rita
G
Guest
Guest
G
Guest
Guest
> >> uses.
Given that this is fixed in a BIOS release, it is implied that this is a
BIOS problem, not a chipset limit....
75GB, is an 'odd' place for such a limit, but is is probably a combination
of internal limits on track numbers/head numbers.
> do not help. :)
> > See?!
Best Wishes
G
Guest
Guest
"Roger Hamlett" <rogerspamignored@ttelmah.demon.co.uk> wrote in message news:UeScc.72$lA5.31@newsfe1-win...
> "Mark M" <MarkM_csiphsCANT_RECEIVE_MAIL@yahoo.co.uk> wrote in message> news:94C482717F4A3A75@130.133.1.4...
> > >> uses.
Obviously.
Which is hard to imagine with the natural CHS addressing limit at 32 GB.
And that's for both ATA interface (P-CHS) and BIOS side (L-CHS).
Which leaves setting size limitations through emulated P-CHS.
That is best left alone since some bioses do unexpected things
e.g. by setting the SET MAX ADDRESS permanently.
> > do not help. :)
> > > See?!
> Best Wishes
G
Guest
Guest
"Mark M" <MarkM_csiphsCANT_RECEIVE_MAIL@yahoo.co.uk> wrote in message news:94C482717F4A3A75@130.133.1.4...
> >> 75 GB because of a limitation in the 440 BX chipset which it uses.
But you *do* know that these type of limitations (bugs) are all software.
> Certainly that is what Gigabyte Tech Support seem to be telling me in emails.
So you jumped up for joy thinking "I finally got a new stupid question to ask".
> I am assuming, perhaps wrongly, that Gigabyte knows more about their
They are mainly marketing operations that buy their boards elsewhere.
They know of problems through persons like yourself or from the operations
that provide the boards and/or firmware. They are just the 'inbetween'.
> Your ejaculations do not help. :)
Hmm, and here I thought that such an attention starved person like yourself
would appreciate a warm shower. *eg*
> > See?!
> Ewr, what does that prove? It shos that my limited experience in
G
Guest
Guest
> all software.
I don't think that is true unless you call embedded code in chips
"software".
>> may be that there is a limitation the 440BX has separately
>> from the LBA addressing limitation.
> question to ask".
Folkie, please take this the right way ... I have no problem if you
wish to beat your old drum and shout out about what you (rather
incorrectly) think is the poor way I approach these things. Maybe
I am insanely stupid and inept. But maybe not.
Whatever I am, I do the best I can. And your repeated inaccurate
observations on my approach will not somehow magically persuade me
otherwise.
Perhaps I should make it my quest to offer endless pedantry in
comments to your postings? Heh!
>> htm Can you read the description for version F2?
>> about their motherboards than I do. It is confusing.
> elsewhere. They know of problems through persons like yourself
> or from the operations that provide the boards and/or
That is a good guess if you misinterpreted what I wrote. I wrote
that I got this info from Gigabyte Tech Support and I mean from
Taiwan. Even if you missed that you coul dhave seen the web page I
referred to and noticed that the Gigabyte company was of the
opinion that version F2 of the BIOS ugrade overcame the 75 GB
limit.
I don't know how I can make this any clearer.
> like yourself would appreciate a warm shower. *eg*
>> > See?!
>> experience in these matters has not encountered this before.
>> I have not seen China but that does not mean it does not
>> exist. Heh!
G
Guest
Guest
On Mon, 05 Apr 2004 13:14:31 +0100, Mark M
<MarkM_csiphsCANT_RECEIVE_MAIL@yahoo.co.uk> wrote/replied to:
>>> uses.
>> perfectly.
I had to run a special program to enable drives that big on my BX
board. I think it was from a HD maker, and I got it on the net.
G
Guest
Guest
"Mark M" <MarkM_csiphsCANT_RECEIVE_MAIL@yahoo.co.uk> wrote in message news:94C510456F6893A75@130.133.1.4
'wrote in' what?
> > all software.
> "software".
There is no embedded code in ATA (host)controllers.
And it is probably the opposite for that sentence to make sense.
> > question to ask".
> Maybe I am insanely stupid and inept. But maybe not.
> otherwise.
Hey, if that keeps you off the street ....
The risk is that you prove yourself to be "insanely stupid and inept".
> > or from the operations that provide the boards and/or firmware.
> That is a good guess if you misinterpreted what I wrote. I wrote that
> I got this info from Gigabyte Tech Support and I mean from Taiwan.
So?
> Even if you missed that you could have seen the web page I referred
> to and noticed that the Gigabyte company was of the opinion that
> version F2 of the BIOS ugrade overcame the 75 GB limit.
So?
Clear enough for me. Doesn't change a word of what I said.
Just pushing a few chips around in a predetermined rectangle
in a CAD program to make the design look different from
someone elses and then ordering some sweatshop to make it and
plonk a BIOS on it directly from AWARD with their name
in it, doesn't make them more than just a marketing operation.
> > > > See?!
> > > exist. Heh!
G
Guest
Guest
So can you explain why Gigabyte are saying there in a 75 GB limit
on this board which their BIOS upgrade overcomes?
G
Guest
Guest
"Mark M" <MarkM_csiphsCANT_RECEIVE_MAIL@yahoo.co.uk> wrote in message news:94CA9C681959B3A75@130.133.1.4...
Because some clown sent them the revised bios saying that it
resolved the 75GB limitation (or something similar obscure).
G
Guest
Guest
>> > rectangle in a CAD program to make the design look
>> > different from someone elses and then ordering some
>> > sweatshop to make it and plonk a BIOS on it directly from
>> > AWARD with their name in it, doesn't make them more than
>> limit on this board which their BIOS upgrade overcomes?
Well Folkert you wont believe this but the last email I got from
Gigabyte tech support said this:
<QUOTE>
I am correct i have one of these boards myself.
Question :
I think you are wrong when you say "im afraid the 440 chipset only
allows up to 75GB".
<UNQUOTE>
Maybe this belief pervades the whole of the Gigabyte organization?
Maybe, just maybe, they are correct.
But I am left wondering what the hell they are talking about and
why they say there is a 75 GB limit. Any ideas what they could be
referring to (bearng in mind that a BIOS flash is said to fix it)?
Surely it could not be that they are unable to write "137 GB" or
"128 GB" and instead they wrote 75 GB by mistake?
G
Guest
Guest
Mark M <MarkM_csiphsCANT_RECEIVE_MAIL@yahoo.co.uk> wrote in
news:94CC968FDACB93A75@130.133.1.4:
I've been following this thread and I don't know what's going on at
Gigabyte but either a) they really screwed up when they wrote the bios or
b) the tech response you received is wrong.
I've got a Tyan Tiger 100 S1832DL motherboard, thats a 440BX Dual. It has
the ATA drive size limit you would expect at 128 / 137 GB, depending on
your method of measuring HD size. It does NOT have a limit at 75GB. I've
verified this by installing 160GB drives on the board controller and
comming up against the 128 / 137 limit.
From the Maxtor site:
http://tinyurl.com/3395l
So I don't know about any BX boards with a 75GB limit, but I can say for
certain my BX board doesn't.
