Question 4K Monitor for After Effects and gaming
Mar 12, 2020
Hey guys can anyone recommend a good monitor for my new Pc. I usually create motion graphic templates in A.E and I will also be doing a good bit of gaming. I have a RTX 2070 Super if that helps . I currently have an Acer R271 which has been okay but since I'm going 4K Id like at least a 32" inch monitor. My budget is around £800 but I could stretch it a little. Thanks for any recommendations.
I have done a lot of searching but I thought I'd ask possibly some one might recommend one that I maybe haven't come across...
Some features that i was looking for in the monitor;
  • Wide Color Gamut: atleast 95 - 100% in either SRGB or DCI-P3??
  • HDR
  • Freesync or G-Sync
  • Nothing higher than 5ms response time
  • IPS Panel
  • Id like to get a monitor that would take advantage of the features of my gpu
