Hi, iam pretty much a noob when it comes to overclocking and i would like some extra juice from my machine for music production etc. i currently have tried overclocking it to 4.2 ghz with 1.184 V and it's pretty stable although sometimes it crashes and gives me the:
WHEA_UNCORRECTABLE_ERROR bluescreen
I also find the Voltage pretty high for the GHZ if i compare to others on the internet, the only thing i did is change base clock to 42 and vcore to 1.184V, do i need to do more to make this stable and maby lower voltage? I tested lower voltages before and it did not really made a difference cranking the vcore voltage up... did i lost the silicone lottery?
For cooling i use a Nepton 240m watercooler and with this settings it stays somewhere around 50 celcius full load Aida64 stability test.
Specs:
Processor: i5820K
Ram: Corsair Vengeance 32 GB DDR4 2400MHZ
Mobo: Asus X99 Pro A
GPU: MSI 290X Lightning
PSU: EVGA Supernova 750 G2 gold
Fans: Silent wings 2
Case: Corsair 750D
Cooling: Nepton 240M LC
I do not really know what settings to turn on and off etc. and what the best way of doing the overclock is so i hope someone is willing to help me out with getting the most from my System
Thanks in advance!
Specs:
Processor: i5820K
Case: Corsair 750D
Thanks in advance!
