Cable management and cleanliness has always been part of a nice custom PC specially with most of the towers/cases now feature tempered glass/acrylic side panel windows. Most people don't really want to expose their cables as much as possible and if they do they resort to purchasing pricey custom sleeved cables (which I did). Because even the high quality premium PSUs out there don't really come with aesthetically pleasing cables:
While they pretty much solved most of cable management exposures by adding a PSU shroud in addition to routing all the cables to the back of the case. The 6/8pin PCI-E connectors are still exposed in plain sight due to the location of the power connector on the GPU. Can't they move this towards the back of the case (basically bottom-right of the GPU instead of top-right) near where the rubber grommets usually are? I think that would make more sense since that way you only a small part of the cables are exposed just like the 24 pin atx and 8 pin eps cables.
Some PSU shrouds do make somewhat a partial solution by having a hole to route the PCI-E cables but there's only a few of these cases and it doesn't work for me.
Is there any other possible solution to this? My custom sleeved 6/8 pin connectors have worn out that I don't really want to buy another set just to replace those.
