[SOLVED] 6 pin RGB fan question
Jennings9
I have a Sahara P35 case which came with 4 RGB fans and a controller, the fans have a 6 pin header which can connect only to the controller, and not the motherboard.
I also have a H100i cooler, which one of the fans have stopped working. I want to replace them with RGB fans but the only way to get them all synced is to buy 2 more of the case fans with the 6 pin headers.
Would it be safe to use those fans, and connect them to the case fan controller and not to the H100i or the motherboard?
I would just like an easy way to sync all the fans together.
If the controller has enough connections and is sata powered does it seem to be fine. Might be that the rgb fans don't perform as good as the original H100 fans,but just test.
Just connect the H100i pump connector to the cpu fan header so you don't get a fault mesage from the bios.
