Build: http://pcpartpicker.com/user/IAmMatt907/saved/2mux
I chose the CPU, because you can upgrade to the AMD FX 6300 later on. The GPU is a good 3 VRAM 7950. The RAM is of course 8 GB. I think the power supply is great, but for the amount of money I have, I think it will suffice. The case I have seen it my friend build he did, that I helped him out with, so I trust the case. The Motherboard is really bad because I couldn't find anything for a low price that was decent quality, so I don't know what to do with the motherboard. A 1TB HDD should be enough space.
This is my first build, so I do need some help on part changes, but I think I have a good build. I am not going to do next gen gaming but BF4, and this PC meets the system requirements. The games I want to play are: Skyrim, Black Ops, BF4, Minecraft, Arma II DayZ Mod, GTA IV, GTA V, Titanfall, Dishonered, Bioshock: Infinite, and a few indie games that I know I can play.
Can this build play this games on medium/high/ultra on a 720p monitor?
I am going to be doing a large amount of multi-tasking, that's why I got the 6 core CPU.
Thanks!
Thanks!
