Question 60hz to 75hz monitor?
breakingjak431
Commendable
Sep 25, 2022
119
6
1,585
Hey all so i basically have a tv not a monitor which is 60hz , basically i want to buy aoc 75hz monitor 21.5 , my main question is , is there a really big difference? Between 60 to 75hz? Also my pc can handle most of the game at 75hz or above abit , but i m just debating , would i feel more comfortable and be better gamer even for 15 more fps ? Most of my games i play are pubg , rocket league , apex legends , thanks in advance
Spec: gtx 970 oc
I7 6700k
16 gb ram
Your PC should be able to handle it without any issues. In all honesty, your mileage can and will vary. At first you might find you have a eye strain or even a headache, it'll go away over time.
For the sake of relevance, which AOC monitor are you looking at?!
Thank you for ur reply , im looking at aoc 22b3hm 21.5...
Difference between 60Hz and 75Hz is not significant enough.
Upgrade to at least 120Hz (or better 144Hz or 165Hz). Then it will be noticeable.
You are right actually , but actually i dont think my pc can handle more than 80fps on fps games like pubg , apex legends etc , especially when shooting , so 75 i would say would be stable , thats im debating , as because i heard that from 60 to 75 would be noticable or atlwast i wont regret buying it?
