65dB Delta fan
cowboi123
137
Do you think it is wise to put three 200+ CFM Delta TFB1212GHE fans in a case. Two attached on a ThermalRight Ultra-120 heatsink and one on the case?????? Any Better cooling effect???
65db isnt noise, its an emergency condition.
Think of a vacuum cleaner or hairdrier noise... times 3.
Ive got a super quiet quad core sys, the fans are scythe FDB fans rated at under 20db, ive also got another 3 (which i dont use) rated at 45db.
45db is LOUD. The fact that its high pitched makes it sound even worse.
I wouldnt even bother ordering those without having a fan controller, that way u can turn them down.
