6600GT and needed power supply
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
Ed Light wrote:
> "First of One" <daxinfx@yahoo.com> wrote in message
> news:AZmdnbRbaaV2tErcRVn-pg@rogers.com...
>> I think he means that, if you buy a generic PSU with two fans, the
>> intake fan would face sheetmetal rather than the CPU/motherboard.
>> The PSU may overheat without any air intake.
> Some do have openings on the back(front?) inside, so if you covered
> the bottom fanit would then work -- but you could just get a 1-fan
> psu with the fan on the back. Those 2-fan units with an opening on
> the back/front inside can blow hot air out it back into the pc and
> cook the CD unit if the bottom fan is working.
Flip the fans?
dvus
"dvus" <dven1invalid@adelphia.net> wrote in message
news:33p5a4F41htiiU1@individual.net...
> Flip the fans?
Not sure what you mean.
outside|fan opening| pc interior
bottom fan
Ed Light
Smiley :-/
MS Smiley :-\
Send spam to the FTC at
uce@ftc.gov
Thanks, robots.
dvus:
> What do you mean by "backwards"?
The rear of my Dell PS is a mirror image of a standard ATX PS. A normal
ATX PS will fit in the case but you would have to cut new holes for the
power plug, switch and fan.
Mac Cool
Mac Cool wrote:
> dvus:
> normal ATX PS will fit in the case but you would have to cut new
> holes for the power plug, switch and fan.
They seem to have gone to a lot of trouble to insure selling a few PSUs!
dvus
news:33p5c8F3vfftdU1@individual.net...
> Mac Cool wrote:
>> dvus:
I'll bet replacement motherboards are hideously expensive.
Ed Light
Smiley :-/
MS Smiley :-\
uce@ftc.gov
Thanks, robots.
news:CYGdnTHCcteoCkrcRVn-gQ@rogers.com...
> That's just bad design. Intentionally perforating a shroud, WTF? Any, the
> perforations would still be facing the CD drive if the PSU were installed
> "backwards".
> My 400W Antec has a 90 mm intake and an 80 mm exhaust fan, without any
> perforations on the enclosure. The air coming out the back is actually
> very
> warm, meaning the fans are doing their job.
I presently have a 1-fan Antec. When I upgrade I'll get a psu with one big
bottom fan.
My psu has very little incoming heat to cope with as I run my hsf fanless
with a duct between it and the case fan, which vacuums all the cpu heat out
the back. As a result my system temp stays in the high teens, low 20's.
Once you do this it's hard to imagine going back.
Ed Light
Smiley :-/
MS Smiley :-\
uce@ftc.gov
Thanks, robots.
dvus:
I'm not sure of the motivation behind the proprietary case and PS, except
maybe to discourage mass production counterfeit Dells, or perhaps to
prevent people from swapping out the PS for a cheap one when they sell the
box. Whatever the reason, I heard they stopped shortly after I bought my
Dell.
Mac Cool
>> Any, the perforations would still be facing the CD drive if the PSU
>> were installed "backwards".
>> any perforations on the enclosure. The air coming out the back is
>> actually very
> one big bottom fan.
> fanless with a duct between it and the case fan, which vacuums all
> the cpu heat out the back. As a result my system temp stays in the
Could you post a pic of your case's interior somewhere? I've been
considering doing something similar and I'm not too proud to copy a good
design.
dvus
>> Mac Cool wrote:
>>> dvus:
>> PSUs!
A friend just left me an AST Adventure! 410 that needs help and it's quite
unique. You actually have to take the cover and bottom of the thing off to
remove add-in cards. I'm searching for the CMOS clearing jumper because I
think the battery went dead and screwed up the bios. Damn thing has mostly
ISA slots and no AGP.
dvus
Most Dell ATX tower PCs since the early Pentium4 days use this design. It's
a 80 mm (or wider) duct, with a 90-deg bend, out of ventilation ducting or
some PVC pipe (Home Depot). If you are cheap, you can use cardboard:
http://www.mashie.org/casemods/pics/syrinix_03.jpg
"War is the continuation of politics by other means.
It can therefore be said that politics is war without
bloodshed while war is politics with bloodshed."
news:33qmvlF44hnf0U1@individual.net...
> design.
> dvus
High teens, low twenties is about room temp; can't go much lower. 🙂
My case's shitty design puts the PSU vertically beside the CPU. (As a
result, the PSU must be removed to access the CPU heat sink.) This
incidentally puts the PSU intake fan directly above the CPU fan, resulting
in low-twenties case temperature. 🙂
"Ed Light" <nobody@nobody.there> wrote in message
news:82PBd.6068$232.5841@fed1read05...
> bottom fan.
out
> Ed Light
> Smiley :-/
> MS Smiley :-\
> uce@ftc.gov
> Thanks, robots.
> design.
I used this little kit:
http://store.yahoo.com/casecooler/suovairdu.html
It's not ideal -- the pipe's a little small and not smooth inside, and on my
system, to get it to fit, I had to mount the case fan on the outside, with
the grille cut out.
It's like the bottom picture only the flow is out, not in.
You can actually try making one with aluminum tape.
Ed Light
Smiley :-/
MS Smiley :-\
uce@ftc.gov
Thanks, robots.
It doesn't seem like so long ago when we had mixed pci and isa, and didn't
want to throw out our isa cards.
Ed Light
Smiley :-/
MS Smiley :-\
uce@ftc.gov
Thanks, robots.
news:6eGdnZoooO006kXcRVn-pw@rogers.com...
Sounds like maybe you're running your cpu fan backwards, blowing into the
psu?
Ed Light
Smiley :-/
MS Smiley :-\
uce@ftc.gov
Thanks, robots.
>> good design.
> design. It's a 80 mm (or wider) duct, with a 90-deg bend, out of
> ventilation ducting or some PVC pipe (Home Depot). If you are cheap,
Thanks for the link.
dvus
>> good design.
> and on my system, to get it to fit, I had to mount the case fan on
> the outside, with the grille cut out.
This should work well since I have 2 exhaust fans on the back of my case.
One could be dedicated to pulling the air from the cpu via the use of some
form of ducting.
dvus
> form of ducting.
You might not need to keep running two.
Ed Light
Smiley :-/
MS Smiley :-\
uce@ftc.gov
Thanks, robots.
>> quite unique. You actually have to take the cover and bottom of the
>> thing off to remove add-in cards. I'm searching for the CMOS
>> clearing jumper because I think the battery went dead and screwed up
>> the bios. Damn thing has mostly ISA slots and no AGP.
> didn't want to throw out our isa cards.
Yeah, I remember being very cautious when a mobo I was considering had 5 PCI
& 1 AGP slot but no ISA's. It worked out fine, of course, but things like
that sometimes go against the grain.
dvus
dvus wrote:
> Mac Cool wrote:
>> dvus:
Could be worse, they could have sized the case so that a standard power
supply won't physically fit.
--John
Reply to jclarke at ae tee tee global dot net
(was jclarke at eye bee em dot net)
>> case. One could be dedicated to pulling the air from the cpu via the
>> use of some form of ducting.
Why not? They're fairly quiet and keep the air flowing. Hell, there's those
two case exhaust fans and one case intake fan on the front near the
hard-drive, plus three built into the PSU, one on the CPU heatsink and one
on the GPU heatsink. Must be like a hurricane in there. CPU stays at about
45C and the case at 38C.
dvus
J. Clarke wrote:
> dvus wrote:
>> Mac Cool wrote:
>>> dvus:
>> PSUs!
> power supply won't physically fit.
Heh, yeah, how did an undevious guy like you happen to think of that? I'm
supposed to be the devious one here.
dvus
news:33trcgF43ff5mU1@individual.net...
> those two case exhaust fans and one case intake fan on the front near the
The only fans running in mine are the 1 psu fan and one case fan and the fan
on the ti4200. System temp is 22C just now. Without the cpu heat in there
it's amazingly lukwarm. Of course alot of fans don't hurt anything if you
don't mind their sound.
Mine are 80mm running at 2100 and 2350 rpm's.
Ed Light
Smiley :-/
MS Smiley :-\
uce@ftc.gov
Thanks, robots.
Yes. There's no right or wrong way of doing it; the direction of fan
mounting depends on its environment. Having the CPU and PSU fans working
against each other naturally doesn't work.
BTW, from what I remember in an Anandtech review, in cramped cases (e.g. 1U
rack), the fan is more effective when blowing upward from the motherboard.
In roomy cases (or on a reviewer's testbench), the fan normally works better
blowing into the board.
Then you have monsters like the Hyper6, whose CPU fan is in line with the
case exhaust fan, thanks to the heat sink's massive height. See:
http://www.metku.net/reviews/hyper6/final.jpg
news:xi9Cd.6587$232.5350@fed1read05...
> psu?
> Ed Light
> Smiley :-/
> MS Smiley :-\
> uce@ftc.gov
> Thanks, robots.
Or use both:
http://www.trustedreviews.com/images/article/page/1964full.jpg
Note the dual-fan cooling shroud over an equally impressive heat sink. Find
the shroud or a current-generation Dimension case on eBay and you are set.
news:33sokbF44ccv9U1@individual.net...
> form of ducting.
> dvus
