6700k dark rock pro 3 temperatures are too much spiking.
rpluume
11
Hello I have made my new pc with 6700k and dark rock pro 3, asus sabertooth z170 mark 1. The thing i have is too big temperature spikes which makes me curious. When im running just chrome with few tabs and in backround is running just anti virus temperatures are spiking from 35C - 60C generally for cpu 1. For cpu 0,2,3 temperatures are spiking from around 35C - 55C. How do you think what could be the problem? Maybe with the thermal paste? I'm making attachment with the temperature charts. Help me please. :)
Temp chart
Thanks, Ramix
wkr6q4pav
Hello everyone who tried to help me with this problem. I have resolved it with so easy way. It was svchost.exe who was running because windows update service was running all the time, it starts to spike my cpu after few minutes. Now when i have disabled this windows update service the svchost dissapeared and the cpu temps are stable on around 22c which is pretty good. :) Thank you for help
Car speed is a bad analogy, ... the faster one takes home 1st place price money and the other one doesn't bring home anything. That's a HUGE difference
While that doesn't matter philosophy may pass muster in a corporate setting for Dell, for the system builder, the challenge for the self builder is building the best PC one can with their budget. How popular do ya think that :doesn't matter" approach is in Rio right now ? And paying more to get less is just silly.
The worse TIM is actually 2.5 times worse at its job then the best TIMs and CPU temps can be 50+% greater than the 3C you stated
http://overclocking.guide/thermal-paste-roundup-2015-47-products-tested-with-air-cooling-and-liquid-nitrogen-ln2/6/
http://archive.benchmarkreviews.com/index.php?option=com_content&task=view&id=150&Itemid=62&limit=1&limitstart=9
"Doesn't matter" can be said about every PC component ...why buy 6600k over 6600 ?
Why buy an AIB 1080 over a 1080 FE ?
Why buy a SSD (boots in 15.6 seconds) over a SSHD (boots in 16.5 seconds) ?
Why pay an extra $20 for a better cooler if the TIM you choose loses the gains from the better cooler ?
But most of all, why pay a ridiculous almost 5 times as much for $18.88 for MX4, when the superior Shin Etsu costs $3.99 ?
So yes, even if you don't care that you didn't do the best you could do, you should care that you wasted $15
There's also other criteria ...
a) Some TIMs have application issues... i.e. have short working times,
b) Some have curing issues ... take 200+ hours to cure (i.e AS5)
c) Some have capacitance issues (i.e. AS5) batter not get any on electrical contacts
d) Some require "warming up" and if applied in cool temps, workability expires quickly
Two things you should do immediately after installing windows (which shoud be done with no ethernet cable connected:
!. Disable WUs ability to install hardware drivers
http://www.tenforums.com/tutorials/8013-windows-update-
http://www.sevenforums.com/tutorials/82137-drivers-turn-off-automatic-driver-installation.html
2. Disable automatic updates
Win 7 - Control Panel / Windows Update \ Chnage Settings \ Check for updates but let me decide whether to download and install them
http://www.tenforums.com/tutorials/8013-windows-update-automatic-updates-enable-disable-windows-10-a.html
This should solve your problem and also protect you from updates that get released / recalled and break something.
When patch Tuesday arrives, I wait 48 hours and look at all the patches on Thursday ... I'll a) install all security patches, b) delete / hide all tracking / upgrade related KBs and c) evaluate and feature updates to see whether they benefit us
@JackNaylorPE - That's just an ignorant comparison of pastes based on price. Why buy mx-4 when it's $18 vs $3 shin etsu? Mayonnaise costs more than gold too if you buy enough of it. New egg sells shin etsu for $10.78 and the $18.88 price for mx4 was for 20 grams of the stuff. That's more thermal compound than I've used on all of my home builds over the past couple decades. You don't have to buy it by the bucket. Mx-4 can be had from newegg btw, 4g for $7.38. Are you getting 20g of shin etsu for $3.99?
Using that same thermal compound roundup you posted, I wasn't talking about coollabs liuquid pro which isn't a common tim. It's got plenty of issues with corrosion unless used properly and not really something I'd recommend to the average builder. Starting with thermal grizzly kryonaut you have 7.88 delta temp difference. Shin etsu wasn't even listed and aside from a couple one off never heard of tim's, there were 30 other thermal pastes including arctic's ceramique 2 with a delta of 10.13. That's a difference of 2.25c which falls in between 1-3 c as I stated. So thank you for proving my point.
At the end of the day, no, 1-3c isn't going to make much difference. If you're within 2.25c of overheating then you need a better cooler, period. A better cooler will drop temps 10-20c. If you crack a window and the temp rises a degree or two there goes all your tim heat savings. It's not worth stressing over and many tim roundups have proven this including yours you posted. It's going to extremes to try and prove a point that doesn't really exist for the sake of being pedantic.
@rpluume, good to hear you solved the issue. As others mentioned, if you decide to turn off windows updates then just make sure you don't forget to run them once in awhile to keep your pc updated.
It's not the greatest analogy, though not for the reasons you're trying to make it out to be. First of all, second place in a professional race actually does take home prize money. Second, two i7's running at the same clock rate, but one is 1 °C warmer, are actually doing the exact same amount of processing work, so there isn't a winner or loser.
Yes, many builders do challenge themselves to get the most performance for the least amount of money. As someone who's competed in the SBM, I think I know a thing or three about that. We typically call it performance value. And spending money on something that has near zero effect on actual performance is a net loss in value.
So you're saying your overclocking is of international importance and your paycheck is based off a 1 °C difference? Spare us the theatrics and hyperbole.
Indeed, quite silly, as I said above.
You best define what you mean by "worse" since that can mean a lot of different factors. Both those links deal with temp deltas. If you want to say the delta can be 2.5 times higher, then that could be true. However, quit with the scare tactics. My goodness, no! I'll have a 50% higher delta than 3 °C? *gasp* That means it'll be an unbearable 4.5 °C higher than if I spent twice as much money on a "better" paste! Woe is me!!!
Knock it off. That first link uses a synthetic hot plate instead of an actual CPU, so the real-world application of those numbers is sketchy. And if you toss out the exotic liquid metal TIMs that the vast majority of people don't use, as well as the commonly recognized bad pastes that no one recommends, your 2.5 factor falls to less than 2.
I also notice you conveniently ignore the conclusion of the second test you linked where they stated that the application and mounting are far more important factors than the TIM ( same as Igor said three years ago ). Not only that, they admit their findings are not without fault.
Well, you can say that, but it doesn't mean the statement is true.
Because I have applications that can saturate threads and they'll see a measurably significant performance increase by overclocking.
Because it's not just boot speed I'm looking for. Perhaps it's lower power consumption, or I have more commonly used applications than can fit in the limited SSHD cache.
Again, define better. Sometimes you pay extra for brand loyalty. Sometimes you pay for something that fits in your case. Sometimes you pay for lower noise. But really, isn't there already TIM bundled with that cooler you just bought?
Better question: why spend extra on third party TIM at all instead of using the paste that comes bundled with the cooler you already have? Also, have you checked the price / volume on your beloved Shin Etsu? Biggest complaint in the reviews is how little you get, two applications at most ( y'know, in case the first one doesn't go right? ). Compare that to the GC I bought for my Tom's review work. One ~$10 tube gave me about 10 applications. Same can be said about many other commonly used pastes. Meaning cost / application is half that of Shin Etsu ( going by your prices ) so the overall value is about twice as high from that standpoint.
Enough with the thinly veiled insults.
Actually I would care more that I spent money on paste that did nothing for my computer's actual performance.
