6950 2gb Sapphire dirt3 2gb problems?
lozotheatheist
64
Ok, Here are my specs.
- Amd phenom ii x4 980 3.7ghz on Antec h2o 620 80% load: 45C
- 6950 2gb Sapphire dirt3 2gb
- 1tb WDBLACK 7400rpm
- 16gb ddr3 1333 PNY
- ASRock 890x AM3+
Problems, I think?
- L.A. Noire
Stuttering and lag w/ 25-30fps Low. Exact same on high/ultra.
*Note: My old laptop 'same res' With a i5 dual core & 6770m ran La Noire w/ no stuttering & 80fps on Low.
- Minecraft
Single player stuttering w/ 50fps.
(How ever, When i play on a server / host on my comp and "Localhost" Stuttering is gone and 250+ fps)
My bro's comp has the same as mine, But with a Phenom ii x6 1090t Same problem.
- Mafia ii
PhysX on: 4fps | MAX
PhysX off: 190+ fps | MAX
Resolution: *All games
1366x768
Not major problems, Besides La Noire, Thanks in advanced for any help!
<3 the community.
randomkid
If you haven't done so, please download & install the latest Catalyst Version for your graphic cards.
THe AMD 6950 2GB or any AMD card does not support PhysX. You need an nVidia card for that, I believe.
lozotheatheist
64
I am running 11.12, should I try beta drivers?
randomkid
No need. I run 11.12 myself on 2 x Sapphire 6950 2GB and its serving me well. But before, I noticed that If I turn on Anisotropic in Catalyst, it reduce my fps so I turn it off.
Something else to try is to install the Catalyst Application Profile... it should not be the cause of your reduced fps but it could improve some.
Latest posts
