7N400Pro2 Rev.1-NOISY North Bridge Cooling Fan-Replacement..
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
Anyone know where I can get a replacement NB fan for this MB?
*OR* care to recomend an alternative solution??? I seem to recall
reading/hearing that there are fanless/passive heatsink solutions 'out
there'?
Anyone know who makes something suitable/where I might consider buying
something? Also-anyone had any HANDS-ON experience with such an
alternative?
Did they work well?
Any trouble doing the CHANGE? (Eg. removing the old heat sink)?
TIA!
http://www.quietpc.com might have something suitable.
Regards
Mike
"Hammer Toe" <HammerToe@online.com> wrote in message
news:m4cr90916bmbulr5brtqtu1jh1d9ivcc65@4ax.com...
> there'?
> alternative?
> Did they work well?
> TIA!
If your mother isnt brand new, and the fan has only just started becoming
noisy then before you do anything rash, try giving it a blast from a can of
compressed air. If that does the trick (you fan noise drops) then consider
adding some kind of filter to your PC's case.
CrimsonLiar
PS: I wonder what the record for dust build up in a PC is, the worst I've
seen is about 4cms spread evenly over the motherboard in a desktop PC, it
came in for a service because it kept crashing (I wonder why)...
> there'?
> alternative?
> Did they work well?
> TIA!
My 7VAXP has been doing this for over a year. I note it does it more if the
room is cold. When it warms up it stops. I just live with it; it is still
going OK.
> there'?
> alternative?
> Did they work well?
> TIA!
